Should I upgrade?
Old Nov 23, 2003 | 05:53 AM
tolowhb's Avatar
Default Should I upgrade?
I just got my greddy kit a few weeks ago and I will not be installing it until the spring, so I am buying stuff that I need to run it right over the winter (new clutch, bov,IC,and boost controller) Now I was wondering if I should go ahead and put in a new walboro fuel pump? I will be running it off the blue box for awhile and I might change to VAFC.
Old Nov 23, 2003 | 07:52 AM
tolowhb's Avatar
Default Re: Should I upgrade? (tolowhb)
Anyone?
Old Nov 23, 2003 | 08:07 AM
RedTegLS's Avatar
For the $100 shipped a Walbro will cost you I dont know why anyone would not buy one. I bought RC 55cc injectors also. Fuel delivery is one of the key factors in going boost. I believe engine management is #1.
Old Nov 24, 2003 | 11:11 AM
Del_Slowest's Avatar
Default Re: Should I upgrade? (RedTegLS)
If you have a good stock pump then don't get it. If you're using the Blue box u def. don't need it. If you use the VAFC hack for higher boost then you might want to get it. Anything less than 8 or 9 psi then you won't need it.
boostincoupe
Dec 16, 2005 02:13 AM
mogz
Dec 12, 2003 01:49 PM
turbod97ex
Jun 13, 2003 06:44 PM
aemciv
Mar 31, 2003 12:37 PM
madman604
Sep 11, 2002 03:03 PM
