should i get boosted?
Old Mar 12, 2002 | 07:44 PM
Frosty_spl's Avatar
Default should i get boosted?
im thinking about getting rid of my EF with b16a and going to a EG with a b20 turbo. what kit is the best for the price? Fmax, Drag, or should i go custom?
I plan to take it easy and keep the boost down, how much boost is safe on a stock engine? 6psi?
thanks for the help!
Old Mar 12, 2002 | 07:50 PM
D-SPEED's Avatar
Default Re: should i get boosted? (Frosty_siR)
i found this thread pretty helpful. good luck
https://honda-tech.com/zerothread?id=144245
Old Mar 12, 2002 | 08:20 PM
SIK IN DA HED's Avatar
New User
Default Re: should i get boosted? (D-SPEED)
im gettin sick of these questions!
Old Mar 12, 2002 | 08:22 PM
2000_Civic_Si's Avatar
Get the kit that you want they are all basicly the same.
Old Mar 12, 2002 | 08:28 PM
Frosty_spl's Avatar
Default Re: should i get boosted? (2000_Civic_Si)
D'OH!
sorry, i shouldve looked first.
Old Mar 13, 2002 | 05:51 PM
WiggiE's Avatar
New User
Why don't you fix your car before you worry about boosting it or putting a new block on it. You can't even afford an oil change! How about fixing your vtec and flushing your radiator since you had your head off for like a week. Or maybe you should remount your motor since it's mounted diagonally and is tearing up your half shafts.
Old Mar 13, 2002 | 08:34 PM
93LSivic's Avatar
1 psi isnt safe if a half *** job is done. And from the last post, sounds like you might blow your motor running .5 psi
Fo-Do Fanatic
Mar 29, 2007 10:39 AM
CACIV
Jul 17, 2005 11:20 PM
94`Gsr_Hatch
Aug 20, 2003 11:01 PM
SOHCam
May 29, 2002 12:02 AM
hondasir1988
Sep 23, 2001 09:23 AM
