View Poll Results: Which one should i choose
oil pressure
22.22%
oil temp
11.11%
keep water temp
5.56%
wide band
61.11%
Voters: 18. You may not vote on this poll
which should i get
Old May 7, 2009 | 04:03 AM
99JDMHATCH's Avatar
Default which should i get
I already have a boost gauge but I'm trying to decide if i should keep the temp gauge or get one of the three. My pod by the way only holds two gauges.
Old May 7, 2009 | 06:52 AM
94c1v1cex's Avatar
Default Re: which should i get
what does ths have to do with forced induction?
if you plan to make changes to the car after its been tuned then a wideband... i always like to have an oil pressure gauge in my cars... just so i know.
Old May 7, 2009 | 07:05 AM
99JDMHATCH's Avatar
as you can tell im new to the site by the number of post i have. I did think this was the right forum to start it in since this gauges do deal with force induction.
Old May 7, 2009 | 12:11 PM
redlinetuning's Avatar
Just get the TunerVisionII and you're set with all the information you need.
Water temp is good to know, but probably not as essential as oil temp and oil pressure, as you'll want to know if your oil pressure drops, you know your turbo could be starving of oil.
Water temps are easier to keep cool because of the radiator, but your oil will get hot fast, once your oil gets too hot , your coolant will never keep up to cool the engine.
Old May 7, 2009 | 03:01 PM
coryfenton's Avatar
X2 for the TunerVisionII
But.... if you cannot get it.
I assume you have the two that go in your gauge bezel i think they call it like frog eye pods.
then get a 3 gauge pillar with
AEM Wideband.
Oil Pressure.
And either Oil OR Water Temp....
Old May 7, 2009 | 03:18 PM
99JDMHATCH's Avatar
^^ i hear you but i dont like the look of all the gauges on the pillar. thinking of leaving the two where there their at. then 2 where the cup holders are. Repleacing the temp gauge with a oil pressure. In my opinion think the water temp is the least important of the 4
Old May 7, 2009 | 03:41 PM
coryfenton's Avatar
Do something like that... i think those are tight... but custom for your car
Integra??
Old May 7, 2009 | 07:31 PM
jhammond_82's Avatar
Reject Papi
air fuel ftw!
pjr710
Jun 9, 2008 04:46 PM
twiztid00002
Feb 3, 2008 06:27 PM
mr abstract
Jan 23, 2007 02:00 PM
elpiar
Oct 26, 2005 11:21 AM
1dumbscreenname
Jul 18, 2003 09:50 PM
