should i be concerned???
Old Apr 23, 2002 | 11:11 AM
98civicEX's Avatar
Default should i be concerned???
did a compression test
180 180 170 180
170 had a little oil on the plug...should i be concerned?
Old Apr 23, 2002 | 11:24 AM
TurboSohc's Avatar
Default Re: should i be concerned??? (98civicEX)
Well they are nowhere near the best I have seen nor worst. I would def do a leakdown test. They should be higher but how many miles do you have on your engine?
Old Apr 23, 2002 | 12:06 PM
PrecisionH23a's Avatar
a compression test wont necessarily tell you everything, which is why a leakdown test is better. also, it depends if you have lowered compression pistons. if you are running say 10:1.0, then i say your numbers are a little low. you shouldnt have oil on your plugs either, are you SURE its oil and not just a little bit of gas combined with carbon build up on your plugs?
[Modified by GudeH23a, 4:07 PM 4/23/2002]
Old Apr 23, 2002 | 01:20 PM
98civicEX's Avatar
Default Re: should i be concerned??? (GudeH23a)
yes, it's oil...i'm on stock internals....and about this leakdown test....to tell you the truth, never done one before, nor do i know how to do it....i'll start looking to see how it's done...thanks...
Old Apr 23, 2002 | 01:36 PM
Flamenco-T's Avatar
you'll need an air compressor...to do a leakdown test
go to your honda dealer, go to the service dept and ask one of the mechanic to do it for 20 bucks or sumthin.. I did..thanks to art..
Old Apr 23, 2002 | 05:08 PM
98civicEX's Avatar
Default Re: should i be concerned??? (Flamenco-T)
okay, now what kind of #'s am i looking for..i'm getting my car dynoed tomorrow, so i'll just have them try it....
SilkyJohnson
13
Feb 15, 2011 05:54 PM
Junkie
Mar 22, 2008 12:21 PM
John.
Jun 12, 2006 08:45 AM
D-Rob
35
Apr 12, 2006 10:57 AM
Azcheron
Jun 23, 2005 09:34 PM
