Drag downpipe o2
Old Apr 23, 2002 | 05:05 AM
vtecsiqt's Avatar
Default Drag downpipe o2
Is there a bung for the o2 sensor anywhere on the drag downpipe if not do i have to have one made or what.... also did that blue wire method on my SAFC.....it pointless the f#%*ing voltage bounces around so much I don't know if I'm running lean one minute from the next
Old Apr 23, 2002 | 05:09 AM
Mase's Avatar
Default Re: Drag downpipe o2 (vtecsiqt)
yes there is an 02 bung on the drag downpipes
Old Apr 23, 2002 | 05:20 AM
Seraph0's Avatar
Default Re: Drag downpipe o2 (CDooMe2)
Just one
Old Apr 23, 2002 | 05:26 PM
inspyral's Avatar
O2 voltage should stabilize at WOT.
Old Apr 23, 2002 | 05:58 PM
TurboSedan's Avatar
New User
Default Re: Drag downpipe o2 (inspyral)
Yes, the engine runs in open loop which will cause the O2 voltage to go up and down quickly. Under full throttle the engine runs closed loop and the voltage will stay the same the whole time pretty much. Then is when you can tell if it is rich or lean.
92HB_HB
May 11, 2005 06:06 AM
gsrboost
Apr 20, 2005 10:02 AM
ScottEK
Aug 9, 2003 03:38 AM
