Shop or myself?
Old Apr 21, 2009 | 07:05 AM
Got Warts's Avatar
Default Shop or myself?
Here is my dilemma. I am going to be getting my car tuned soon, as soon as I throw my turbo on. Right now the car is using Crome Pro. I was going to go buy Ectune yesterday, but I got thinking.
How many of you change your tune once it is all set up? Should I just go to a shop, get it tuned on Crome Pro and be done with it? Or should I order Ectune and be able to change my settings later?
On my last car I had full coilovers but once I had it where I wanted it, I never touched it again...will tuning be the same thing? I have a boost controller so I will be able to up the boost when needed.
Old Apr 21, 2009 | 07:14 AM
redlinetuning's Avatar
Default Re: Shop or myself?
"up the boost when needed"... say you tuned your car to 12psi, you can't just push the boost controller dial to 18psi and expect it to run the same, or faster. It's not that simple.
You can change your settings with Crome Pro, but you will need the editor and a datalogger.
Old Apr 21, 2009 | 07:16 AM
GT35R_EF's Avatar
Make mine whatever you want
If you don't plan on making many large changes in the near future just get it tuned and leave it at that. It also depends on your setup. Those of us that are constantly changing things are the ones who are datalogging and adjusting things at the track. If it's just a street/pump gas tune I wouldn't worry about it.
Old Apr 21, 2009 | 07:35 AM
Got Warts's Avatar
I was told that I can tune it at a higher boost then lower it down via the boost controller for daily driving. Then, when wanted/needed, I can up the boost.
True? Make sense?
Old Apr 21, 2009 | 08:04 AM
solo227's Avatar
yes
Old Apr 21, 2009 | 08:07 AM
Topdawgg's Avatar
I ran mine for 2 years without touching a thing... Never had the need to.
This year, I bought S300 and I cant wait to be able to make any changes I might need.
Not so much with the fuel maps or ignition tables, but for boost per gear, rev limit, and the other things for the track..
Also, Its always good to spend extra time on partial throttle to get the gas milage JUST right..
Old Apr 21, 2009 | 09:32 AM
blaze the chemi's Avatar
That's what I'm talking about. When I boost again and have it tuned, I'm getting the tuner for an extra hour or so while we drive around town to dial in the extra breakpoints for daily driving. He was good on my last tune because I was consistant between 26-28 mpg in city and 34 mpg hwy.
Old Apr 21, 2009 | 09:46 AM
raene's Avatar
Warts, just tell the tuner, whoever it is, that you're not running a set boost all the time. Some people, myself included, will sometimes do funky things to help with spool or midrange power.
Old Apr 21, 2009 | 10:55 AM
Got Warts's Avatar
Thanks everyone...
I will just leave it to a shop, and make sure he spends enough time on it for the daily driving portion as well.
teddy_dc2
Aug 6, 2006 07:10 AM
aalb1
Nov 15, 2005 02:09 PM
ochsy03
Mar 24, 2005 08:53 AM
Snafu-Si
Jul 12, 2003 10:12 AM
tygsr
Jun 19, 2002 01:27 PM
