The Shodan & Project GHOST!!
Well, not much to update, except that thanks to Xenocron's suggestion, we called up AEM and were able to swap out the Gen 1 30-1000 unit that he had for the V2 Box, which should be here in about a week.
So going from
To this:
Full USB support, even higher resolution, and best of all, less expensive than if we sold the old new one and put the money towards the new unit.
Next week, we're also picking up from my man, Greg of Go-Autowerks
But the couplers will be black instead of BLUE.
After that, here's the rest of the list
• FX400 Clutchmasters Clutch
• Go-Autowerks 2.5” Intercooler piping – powder coated white
• FIC 1000cc injectors – Fit into the BDL
• Walboro 400lph
• Exedy 12lbs flywheel
• Profec B Spec II boost controller
• AEM oil pressure gauge – black – digital
• AEM oil temp gauge- digital
• Earl's Oil Cooler – 2013
• B&R water fitting kit
• B&R catch can
• DEI Blanket / Wrap kit.
• Liquid filled fuel pressure gauge for BDL Fuel rail
• DSS 4.9 axles – Scheduled for 2013
• AEM/ Cooling mist Meth water – Scheduled for 2012
• Street & Strip / Mallory Digital 7 Ignition box
• MSD Ignition 8253 external coil
• Ingalls Engine dampening stiffy
• Samco rear hoses back of the block
• Frozen boost couplers/t-bolt – Black
So going from
To this:
• Walboro 400lph
• B&R catch can
The initial "Video" of the engine when he picked up the engine is pictured below. under the video are the specifications of the engine. Please note that not all parts me neither recommended by me or J3573r. This was from the previous "builder" before going to Autowerks Motorsport. J3573r decided to just keep what he had an not try to resell and change out.
This project was put on the back-burner for a while because of the fact that the engine needed to be inspected and cleared by Autowerks chief mechanic Andy N. He found several issues that would have proven catastrophic if not at least costly had he not performed this inspection. Once this check was performed, he completed assembly.
Specifications of the engine. Please note, some of these parts are controversial and not of our original design
B18C1 - Engine Block
*PROBE PISTONS -81.5mm 10.0:1 Stock sleeves
*PROBE RODS
*ACL Bearings using a micrometer to confirm measurements
*ARP Head studs
*ARP mains
*ARP Rod bolts for PROBE rod replacement
*ARP Crank pulley, clutch & Flywheel Bolts
*OEM GS-R Crank 87.2mm
*OEM P72 Head Gasket
*MOROSO 5QT Oil Pan
*Gates High Tension Timing Belt
*OEM GS-R 22T Water Pump
*OEM GS-R Oil Pump
*B&R Fittings Catch can and water line kit - PENDING
*Clutchmasters FX450 - Pending
*EXEDY 9lbs Flywheel
Cylinder Head
*GS-R Cams - Temporarily - May go to Skunk2 PRO1 next year
*OEM cam gears - (Thanks to Californiadad for the idea)
*SUPERTECH FULL VALVETRAIN
*SUPERTECH Flat-top NITRITE-TREATED VALVES
*SUPERTECH VALVEGUIDES
*"3-Angle" Valvejob
*OmniPower 68mm Throttle Body
*OmniPower 4bar Map Sensor
*OmniPower TPS
*SKUNK2 PRO1 Intake Manifold
*BDL Fuel Rail
*BDL Cam Seal
*BDL Fuel Pressure Regulator
Forced Induction Components
*Spoolin' Performance Quick4 AC Exhaust manifold
*Spoolin' Performance 3" 4 Bolt Downpipe
*TiAL 38mm Wastegate 14psi wastegate spring
*TURBONETICS "Godzilla" Blow off Valve
*Go-Autowerks 2.5" Intercooler Piping - PENDING
*MISHIMOTO 31 X 12 X 4 Intercooler Anodized
Turbocharger
*STC GT3584R "Reaper" Ball-bearing turbocharger Upgrade from a Kinetics Motorsport GT3582R
*T31 2.5" 4 bolt turbine housing .63A/R turbine housing
*PROBE RODS
*ARP Head studs
*ARP mains
*MOROSO 5QT Oil Pan
*OEM GS-R Oil Pump
Cylinder Head
*"3-Angle" Valvejob
*OmniPower TPS
*BDL Fuel Rail
*BDL Cam Seal
Turbocharger
i know this is old but damn i want one lol
Last edited by Schister66; Jun 13, 2012 at 02:50 AM. Reason: In the interest of bandwidth, don't quote every picture in the post...
so can i expect to see you guys next year for midnight madness at us131 motorsports park.
you looking to take this down the 1320 and if so what are the goals
I'll be a spectator for the midnight madness, but I'd rather race my own car at Beaver Run and run with the Porsche classics
No. that was the original cover of the GT35R from 1998 from Kinetic Motorsport. It came like that originally. I simply upgraded what was there.
