see anything wrong with my return line?
Old Nov 28, 2006 | 04:01 PM
biada1's Avatar
Default see anything wrong with my return line?
i think the return line is way too long.... shouldn't it be shorter and be diagonal? instead of going down. then straight, then to the pan?
i do have some oil leaking out of the turbo somewhere.
Old Nov 28, 2006 | 04:25 PM
memorybox's Avatar
Default Re: see anything wrong with my return line? (biada1)
oil return lines run off of gravity. idealy you want it to go down and at an angle to your oil pan
i dont know if you are safe or not, depends on how far down it goes before it gets flat like that.
Old Nov 28, 2006 | 04:35 PM
Schister66's Avatar
Man U FTW
yeah, thats going to end badly....you're going to want to redo it for sure
Old Nov 28, 2006 | 04:49 PM
platinum00's Avatar
no good man. you always want a slope going to the oil pan
platinum
Old Nov 28, 2006 | 04:50 PM
s2kdre's Avatar
Default Re: (Schister66)
yea mine wasnt as bad as urs and my turbo was smoking from the oil backing up.
Old Nov 28, 2006 | 05:11 PM
shortyz21's Avatar
Default Re: (s2kdre)
o **** son.
Old Nov 28, 2006 | 05:15 PM
yee SERIOUS's Avatar
negative, please try again.
i would probably cut it shorter. get more of an angle/incline in the hose. you don't want any slack.
Old Nov 28, 2006 | 05:17 PM
slo_crx's Avatar
is the return line th eheater hose or the steel braided one?
Old Nov 28, 2006 | 06:33 PM
HiProfile's Avatar
Default Re: (slo_crx)
My oil spends half its journey going sideways, although my line is half as long as that. The only reason I can figure I don't have toasted seals is that I put it where crank weights don't slosh oil on it, I have a restrictor before the turbo, and I never stop acceleration
Try to shorten it up as much as you can without kinking it. If it wants to kink, you can slightly combat it by putting an SS clamp on it lightly to keep it round.
Old Nov 28, 2006 | 06:34 PM
93CX's Avatar
That looks awful, I'd fix it before you drive the car again.
Old Nov 28, 2006 | 06:40 PM
0bd1_Kanobe's Avatar
Default Re: (93CX)
No you should ad about a foot more of hose, that will do the trick . You return hose should not be more that 10-12 inches, that to me look way longer than that
Old Nov 28, 2006 | 07:25 PM
Default Re: (biada1)
Also depends on the manifold you use and engine you are running. What motor and mani are you running?
Old Nov 28, 2006 | 07:33 PM
biada1's Avatar
Default Re: (0bd1_Kanobe)
LS motor and a drag manifold. turbo sits real low... i think its is why im leaking oil somewhere on the turbo...
turbo is probably gone by now. been driving like this for 4 months. i revently installed an oil restrictor and it helps a little bit. not smoking as much as b4.
Old Nov 28, 2006 | 07:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0bd1_Kanobe &raquo;</TD></TR><TR><TD CLASS="quote">No you should ad about a foot more of hose, that will do the trick . You return hose should not be more that 10-12 inches, that to me look way longer than that </TD></TR></TABLE>
mine was about 12 inches or so. haha. but it came straight down, top mounted turbo.
Old Nov 28, 2006 | 08:06 PM
Yeah, you should try changing to a smaller return line and try not to leave exesive slack, like they mentioned they work off of gravity
Old Nov 28, 2006 | 09:50 PM
I.C.C.'s Avatar
i smell disaster...
Old Nov 29, 2006 | 03:43 AM
Mugencrxsir1's Avatar
Default Re: (I.C.C.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">negative, please try again.
i would probably cut it shorter. get more of an angle/incline in the hose. you don't want any slack.</TD></TR></TABLE>
Old Dec 6, 2006 | 12:28 AM
biada1's Avatar
Default Re: (Mugencrxsir1)
update, i was told it cannot be shorten. if i did the lines would kink. i think imma get a new line with a 45 degree end on one end so that it would be a lot easier to work with. hopes this helps cuz turbo is leaking oil..
Old Dec 6, 2006 | 02:51 AM
Flashmn's Avatar
My returnline is like 20 inches or so, I know I might have problems but I'll try to fix them when I get to it
Old Dec 6, 2006 | 04:32 AM
salman's Avatar
ur turbo will start to smoke,
Old Dec 9, 2006 | 02:43 PM
Flashmn's Avatar
Default Re: (salman)
Maybe so... but I cant exactly do it shoter either :D
heck the turbo sits in such a position
Old Dec 9, 2006 | 02:49 PM
97grnrs's Avatar
Default Re: (Flashmn)
ot but where did u get that metal line like that? im using high temp rubber but if i could find hose like that to clamp on it would be much better
Old Dec 9, 2006 | 06:35 PM
I.C.C.'s Avatar
Default Re: (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">ot but where did u get that metal line like that? im using high temp rubber but if i could find hose like that to clamp on it would be much better </TD></TR></TABLE>
pretty much any racing/high performance shop... just steel braided hose
MrDomino
Jul 7, 2010 08:30 AM
the.hamburglar
Jul 11, 2005 06:50 PM
slo_crx
Oct 6, 2004 08:30 AM
alfee
Jun 28, 2004 04:10 PM
torr
Apr 14, 2004 07:48 AM
