searched.. boost + IAT sensor
Old Jun 7, 2008 | 06:39 AM
ShortbusEK's Avatar
Default searched.. boost + IAT sensor
ive done a little searching but have come up with not much.. i have boosted b16a2 in a 97 hatch running crome on a converted p06.. my stock IAT was in my intake arm.. I want this sensor functional not just hanging in the engine bay.. is there any kind of screw in sensor that will work same as stock? plug-n-play is a plus =P
Old Jun 7, 2008 | 08:45 AM
ShortbusEK's Avatar
Default Re: searched.. boost + IAT sensor (ShortbusEK)
ive found the GM iat sensor that screws in.. but its does not give the same readings as the honda iat.. is there a way to change things up in crome?? ive looked around a bit but nothing as of yet
Old Jun 7, 2008 | 09:07 AM
NIGHTRIDER27's Avatar
i used my stock iat but i welded an aluminum bung in my charge pipe, i went to the hardware store and found a brass fitting that was like a 3/4 to 1/4 npt thread or something like that and stuck my stock iat in it and then sealed the iat in it with epoxy its holding up great. i can post a pic of it later i need to pull it out and take a pic of it for you if you want.
Old Jun 7, 2008 | 09:27 AM
ShortbusEK's Avatar
Default Re: searched.. boost + IAT sensor (NIGHTRIDER27)
good idea.. i think i know exactly what you are talking about! but a pic would be a good idea.. if not for me but for anyone ever running across this thread.. because there is not much info available on this sensor on HT
ROOSTER.
Jan 31, 2014 05:42 PM
pjr710
Apr 3, 2009 08:25 AM
b20beast83
Jan 11, 2009 10:43 AM
irishflame27
Dec 19, 2008 09:34 AM
civic-dx
Jul 31, 2003 09:27 PM
