sealing a weld????
Old May 5, 2004 | 02:55 PM
5STAR3's Avatar
Default sealing a weld????
i tapped my oil pan and i had a very tuff time getting the gun into the space to weld the portion up by the lip. it looks like there is a VERY small hole somewhere in my weld.
is there a sealer that i could use? i was thinking something like JB weld maybe. anyone have some good ideas, that is someone who knows. because i can guess just a good as the next guy
Old May 5, 2004 | 03:23 PM
gritsak's Avatar
Default Re: sealing a weld???? (envision2teg)
i think jb weld is about your only other option if you cant get in there with a welder...just remember to clean the area really good first
Old May 5, 2004 | 03:33 PM
EMod Civic's Avatar
Default Re: sealing a weld???? (gritsak)
JB weld works fine for something like that. Mine's the same way, and has held up for 4+ years with no leaks.
-Chris
Old May 5, 2004 | 05:11 PM
sporkcrx's Avatar
Default Re: sealing a weld???? (EMod Civic)
I had the same problem with my fat mig gun when trying to get a weld on the top of it. I just tried my best, threw some paint over it, and it doesn't leak a drop so I guess it's fine.
Old May 5, 2004 | 05:20 PM
raene's Avatar
Weld the inside + grind it flat.
The oil shouldn't be pressurized there anyway so the worst it would do is seep or drip.
Old May 5, 2004 | 05:23 PM
dunkd's Avatar
JB
Old May 5, 2004 | 06:11 PM
5STAR3's Avatar
Default Re: sealing a weld???? (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">Weld the inside + grind it flat.
The oil shouldn't be pressurized there anyway so the worst it would do is seep or drip. </TD></TR></TABLE>
yea i did get the inside too.
its no bad at all i just must have missed a pin hole some where.
ill try the JB
Old May 6, 2004 | 09:32 AM
jmagner's Avatar
there is always a little pressure in there, even if its air pressure.
Old May 6, 2004 | 09:51 AM
raene's Avatar
Default Re: sealing a weld???? (jmagner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmagner &raquo;</TD></TR><TR><TD CLASS="quote">
there is always a little pressure in there, even if its air pressure.</TD></TR></TABLE>
That's a job for a better PCV system
Old May 6, 2004 | 10:12 AM
TRE_'s Avatar
same thing happen on my buddies golf when we put the turbo kit in. jb weld fixed it fine.
Old May 6, 2004 | 10:15 AM
USDM 4G VTEC's Avatar
Default Re: sealing a weld???? (High Noon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by High Noon &raquo;</TD></TR><TR><TD CLASS="quote">JB weld and once it drys, lay a thin layer of Hondabond over it and it will never leak.</TD></TR></TABLE>
i second this
sporty240
Welding / Fabrication
15
Sep 28, 2006 06:33 AM
Vtec92Civic
Aug 21, 2003 08:36 PM
asianspeed
Jan 27, 2003 06:26 PM
DC2R714
Jul 19, 2002 05:25 AM
