SC61 on stock ls?
Old Apr 26, 2005 | 03:04 PM
boostedDC's Avatar
Default SC61 on stock ls?
i have an sc61 turbo with a 6psi spring in the wg, how long do you all think the stock motor would last on 6psi tuned without getting into boost too often? plan to build a motor if i dont go lsvtec with a vortech but will take some time and would like some pwer in the mean time.
Old Apr 26, 2005 | 03:06 PM
b18prl's Avatar
Default Re: SC61 on stock ls? (boostedDC)
ask darin d. on here his old eg had stock ls running 18 psi before
Old Apr 26, 2005 | 03:08 PM
B18Flip's Avatar
you should be fine as long as you stay ontop of regular maintenance.... and why not stick with the sc61 turbo setup after you build the ls/vtec? It'll be crap loads better than a vortech imo
Old Apr 26, 2005 | 03:23 PM
boostedDC's Avatar
ive talked to darin quite a bit, i want to do a vortech because its something different, a year or so ago when i decided i wanted to give imports a shot darins eg was one of the few boosted hondas around here, now there all over the place
Old Apr 26, 2005 | 03:55 PM
b16sedan's Avatar
Default Re: (boostedDC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedDC &raquo;</TD></TR><TR><TD CLASS="quote">ive talked to darin quite a bit, i want to do a vortech because its something different, a year or so ago when i decided i wanted to give imports a shot darins eg was one of the few boosted hondas around here, now there all over the place </TD></TR></TABLE>
That would be like me saying "I'm a man, but I'm going to cut my junk off because it would be something different." or "I'm going to swap out my B18C5 for a yugo motor, because it's something different"
Trust me, in this case you don't want to be different. I had a Vortech, and if it tells you anything I will never own one again.
Old Apr 26, 2005 | 04:22 PM
rob d's Avatar
Default Re: (b16sedan)
i've had my ls boosted with sn sc61 for 30k now 10psi
Old Apr 26, 2005 | 06:33 PM
boostedDC's Avatar
thanks for everyones input, im workin on an ls vtec with forged pistons and rods and im gonna stick to the turbo, i heard the vortech takes forever to build boost. im gonna shoot for 350whp on my lsvtec on pump gas and hope i come up a little higher
mayhem87
Dec 23, 2007 07:02 PM
Eran
Jan 21, 2007 05:53 PM
KiNG $h!t
Jun 28, 2004 12:31 PM
Bictorious
Jan 28, 2004 08:28 AM
DownBoyDown
Mar 26, 2003 10:43 PM
