SC61 Pick
i am in the market in getting a sc61 turbo for my ls/vtec motor.. my goal is 500 to 600 to the wheels.. but i will be happy with numbers close to what my goal is.. i have been researching about the sc61.. and i am hooked on it, but i dont know which one to get.. could somebody help me out.. i know how to read the maps and what the numbers means.. but i am not really sure on which one to get for some reason this time..... thanks a lot...
which seller should i go to on here... i see prices from 700 all the way to 900.. and it is the same product.. i am really lost on that... i dont who to buy it from on here cause.. i am no the one to buy really cheap stuff. but i don't like spending a lot of money if i don't have too.. thanks again...
What bore size are you planning on running? What turbo kit? Cams? Exhaust? Here's a B series set-up that I tuned last month running the t3 sc6152e.
You may want to look into upgrading to the new billet turbo's that PTE offers. They are a verrrrry nice!
i have a 84.5mm sleeved block.. with b16 head with gsr cams.. i am running a ramhorn manifold... with hondata s300..
was that turbo maxed out??? how much boost was that at..
I am running the sc61 with t3 .63 hot side/.60 cold side, ramhorn, stock sleeves, forged internals, type r cams, 3" dp to e-cutout. Made 456whp @ 19psi on 93 octane fuel. The turbo really came alive after 15psi. I dont think 5-600whp will be a problem with that turbo. I would recommend the larger t3 or even t4 exhaust cover with a vband. Good luck!
i'm also interested in the same turbo. I'd personally like a little better spool than the graph posted above, but also looking for the 500-600 cababilitys in the 800$ and under price range.
SETUP:
84x89 Sleeved 9.0:1 Compression
CNC Ported Head 2mm larger valves
Edelbrock Intake mani & TopMount Turbo manifold
I'm not interested in paying big bux for BB (will exceed the budget)
SETUP:
that is not going to happen regardless of wheel combination for the power intended. face it, you're a small displacement engine with a very large turbocharger. On any B-series less than 2 litres, it will more than likely be about 4600-5500 rpms for maximum pressure.
Just want something that is gonna push the car to a 10sec. pass on the track, yet not be a complete waste on the street. (still in the 800 or less price range)
i pretty much went through the same situation as you...i say get the sc61! its the best bang for the buck turbo..i think..
i have a sc61(.63ar) 84.5 bore gsr...i made 604whp @ 31psi! the tune was really conservative too..fastest time i got was 11.2 at 540whp 27psi..still learning..haha..but im trying to get into the 10s also and didnt get a chance to run the 1320 with the new tune..
as far as the street...because of the bigger displacement (2.0), this turbo is crazy...on the street i just run it off the wastegate spring (14psi) and i hit full boost at around 4500rpm...to me thats pretty fast... i say go with this turbo, its proven and the price is a steal..
the only thing i wish i got was a gt35r but that was way over my budget...then i ran in to the sc61 which is pretty much a non ball bearing gt35r...
now i want more!! haha..hopefully i can get a bigger exhaust housing as will..may be a .82ar
just my .02 cents...good luck bro...lmk if you need any more advise
thanks for the input
You can't get everything in the world in one turbocharger. Even the VNTs have their limitations for use. 10 second passes (I assume 10.5+) are quite possible with this turbocharger, and if especially the budget is under 900 dollars, this is one of the only possibilities you can use on pump/race gas.
http://www.tunertoys.com/Garrett_T3_...15583-5007.htm
COMPRESSOR SPECS:T04S
housing flow: 61 lbs/min 781cfm
.70 A/R housing
60 TRIM wheel
TURBINE SPECS:T3
.82 A/R housing
HIGH FLOW 76 TRIM stg3 wheel
oil lubricated centersection.
COMES STANDARD WITH 360 DEGREE THRUST BEARING!!
supportable of 600whp!
THOUGHTS??
that would be fine with me.
I use to run a sc6152sp with a .63 a/r hotside t3 4 bolt housing. was a great turbo, spooled up nicely on bigger sohc f22... hotside was a little restrictive on the big end but thats something I have since addressed in going to a new precision turbo.
Great turbo for the money... if I was to buy another one sc61 I would buy the sc6176sp with an .82 housing.
I would have gone that direction and was going to as I wanted to drop the backpressure in my setup with a larger hotside. Then after checking some pricing on one of the billet precision units someone suggested to me, I just went that route. So I am taking a chance with something a little different (at least not well tested yet in the honda community). Come spring and a retune, we shall see if it along with some other changes is a positive step. I am hoping the improved efficiency will outweigh the drawbacks of additional lag... which lag has never been quite a big issue for me anyways unless its extreme.
Thanks, that helps.
So I think the SC6152xx is supposed to have what is referred to as a "Stage 5" turbine wheel in it, which I guess corresponds to the "52" in the model name of the turbo.
Assuming that's true, is there a common name for the larger "76" turbine wheel in the SC6176xx?
And one more thing, when you mentioned increased lag, is that because of the increased inertia of a heavier billet wheel, or something else?
Thanks for educating me!
Thanks!
So then here's the dumb follow up question: Does this mean that all SC6176 turbos are T4s, or do they find some way to cram that wheel into a T3 turbine housing?
phiberoptik
Sep 15, 2004 07:02 PM
manekDC2.
Jun 15, 2004 11:44 AM
Ratius49
Mar 5, 2003 11:55 AM
