SC61 on LS
Old Feb 17, 2004 | 05:53 PM
  #26
b18b1hmtlove's Avatar
now show me that exact setup w/ just your normal t3/t4. i bet they both make the same power. which is my point, precision turbos arent proven to make more power compared to your run of the mill t3/t4
without running the exact same setup minus the turbo change it would be impossible to do this experiment and get accurate results
Old Feb 17, 2004 | 06:03 PM
  #27
Mr. Softee's Avatar
Default Re: (b18b1hmtlove)
start another thread for that debate, it detracts from the debate of this thread, the appropriateness for the sc61 on LS motors.
thx
Old Feb 17, 2004 | 07:07 PM
  #28
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1hmtlove &raquo;</TD></TR><TR><TD CLASS="quote">now show me that exact setup w/ just your normal t3/t4. i bet they both make the same power. which is my point, precision turbos arent proven to make more power compared to your run of the mill t3/t4
without running the exact same setup minus the turbo change it would be impossible to do this experiment and get accurate results</TD></TR></TABLE>
What is a run of the mill t3/t4 that is similar to the SC61? Find one please..
Old Feb 17, 2004 | 07:14 PM
  #29
SC61 has a a/r of .63 right? compare it to a .63/.60 T3/t04e and i bet they make the same amount of power under 350whp
Old Feb 17, 2004 | 07:19 PM
  #30
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1hmtlove &raquo;</TD></TR><TR><TD CLASS="quote">SC61 has a a/r of .63 right? compare it to a .63/.60 T3/t04e and i bet they make the same amount of power under 350whp</TD></TR></TABLE>
Do you actually know what differentiates the sc61 from the standard garrett t3/to4e's or are you just trying to be anti-sc61? I ran a t3/to4e 60 trim .63ar with my old setup. It made 307@14psi, im willing to bet @ 14 psi my sc61 will make more than that.
Old Feb 17, 2004 | 08:13 PM
  #31
nevin's Avatar
Default Re: (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">it might not be 'that bad' but why pay more for less. By this I mean you are paying $700 for a turbo that isn't efficient for under 300whp. You will lose midrange and have a slower spool up, but you will have the sc61 BLING factor. A smaller t3/t4e is much more suitable for under 350whp as it is much more efficient at lower flow levels and thus produces much more midrange power. A broad powerband is obviously ideal, and having an LS motor basically essential or you will drop to low power levels when shifting.</TD></TR></TABLE>
It isn't really "less" though. I see it as an investment. I had plans to do things like built block/vtec head/standalone/ect but got a good deal on a used sc61 with .70 S compcover (+$100 option) so I went for it. When I talked to art he said that it starts being efficient at about 8 psi so it would work for now AND I wouldn't have to upgrade it come time I want more power. Who dosen't eventually . But yeah if you don't ever plan on upgrading I agree a t3/t04 would be much more suitable. And honestly it wasn't THAT bad, it would spool 10 pounds by 4800ish and pull like a train to 7k, I didn't mind it at all.
Old Feb 17, 2004 | 09:41 PM
  #32
Mr. Softee's Avatar
Default Re: (nevin)
well if you eventually plan on making 400whp+ then obviously its a good choice
that goes directly inline with what I said. However using it for less power is not a good idea.
DJNauTicz
Aug 17, 2007 08:28 AM
kbear
Aug 16, 2006 05:08 PM
SpoolnByYou
Oct 12, 2005 03:19 AM
Team Underground Teg
May 2, 2005 04:49 PM
Patron
Sep 26, 2004 10:38 AM
