which turbo is more efficient for ls?
Old Oct 10, 2005 | 01:57 PM
SpoolnByYou's Avatar
Default which turbo is more efficient for ls?
sup guys,
im stuck between these 2 turbos,which one sounds more efficient for the ls?
http://store.yahoo.com/cheapturbo/gat3w48ar.html
http://store.yahoo.com/cheaptu....html
Old Oct 10, 2005 | 02:11 PM
turboEGhatch's Avatar
Default Re: which turbo is more efficient for ls? (SpoolnByYou)
How about a power goals instead of a random and completely useless "which one is more efficient"
Old Oct 10, 2005 | 06:55 PM
already have a power goal,right now 250,but later want to try and get higher.
Old Oct 10, 2005 | 07:29 PM
xenocron's Avatar
The second one is probably a little closer to the 'norm' that people go with on the LS.
Stick with the 50-57 trim T3/T4's
Old Oct 10, 2005 | 09:23 PM
TheShodan's Avatar
Moderator
Default Re: which turbo is more efficient for ls? (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">The second one is probably a little closer to the 'norm' that people go with on the LS.
Stick with the 50-57 trim T3/T4's </TD></TR></TABLE>
Or even the GT32 series..
Here's a dyno of the last GT32 "Blue Pill" I created for a STOCK LS w/ E-manage and 440cc injectors, 38mm .4 bar wastegate and about 10 psi on 93 pump gas w/ stock plugs.
Old Oct 11, 2005 | 08:24 AM
Oyvind Ryeng's Avatar
Default Re: which turbo is more efficient for ls? (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
http://img.photobucket.com/alb...b.jpg
Wich compressor wheel? A/R of the housings?
Old Oct 11, 2005 | 11:18 AM
Maveric's Avatar
Default Re: which turbo is more efficient for ls? (Oyvind Ryeng)
"the second one"
if you only want 250whp a 50 trim with a .48 a/r will
do you very good....give ken a call over a phoenixturbo.com
he'll take care of you
good luck
Old Oct 11, 2005 | 11:20 AM
well i was actually leaning to getting the t3/60-1
why would you reccommned the 57 trim over the t3/60-1?
i know the 60-1 is a lil big,and spool time wouldnt probably come in till about 3,5-4,but the 60-1 flows 11 more lb/min then the 57 trim.
what are your opinions of the pros and cons of the 60-1 vs the 57 trim
and yes my goal is right as we speak 250whp. but then after that i want head work to get done in hopes of 300....then 350....and so on
also...on the first turbo the turbine wheel is a: HIGH FLOW 76 TRIM stg 3 wheel,but the exhaust a/r is .48
how do you think this will play in spool up for the ls?
Modified by SpoolnByYou at 12:47 PM 10/11/2005
Modified by SpoolnByYou at 12:55 PM 10/11/2005
Old Oct 11, 2005 | 01:59 PM
spoolin turbo s's Avatar
you would be an idiot to get the 60-1
simple as that
Old Oct 11, 2005 | 02:40 PM
Default Re: which turbo is more efficient for ls? (spoolin turbo s)
oh how could i be so stupid!
i forgot you are the car god and everything you say and do is best because you are just an expert at everything you do!
you are an idiot for posting without facts...simple as that
anyways...i tried e-mailing ken at phoenixturbo to talk to him but somethings wrong with the e-mail i guess,it says address not found. so i guess its still 60-1 vs 57 trim.....
Old Oct 11, 2005 | 06:34 PM
EARLdaSQUIRREL's Avatar
official honda whore
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin turbo s &raquo;</TD></TR><TR><TD CLASS="quote">you would be an idiot to get the 60-1
simple as that
that must mean full-race are idiots for offering the 60-1 with their stage 2 kits. and im even more of an idiot for having one on my ls and having around 250whp now and shooting for 400 after tuning
stfu and only offer people good advice and if you have somethign bad to say about something back it up with atleast some information
Old Oct 11, 2005 | 06:40 PM
Default Re: which turbo is more efficient for ls? (coptzer)
Most I've seen on a T3/60-1 is 640 WHP. It's definitely overkill for your setup. The 57-trim will support atleast 450 WHP and do everything you want with quicker spool and a better powerband.
Old Oct 11, 2005 | 08:16 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oyvind Ryeng &raquo;</TD></TR><TR><TD CLASS="quote">
Wich compressor wheel? A/R of the housings?</TD></TR></TABLE>
The housings are irrelevant. They are your standard .60A/R (which I can port and squeeze great out of a .50A/R for the compressor, and a .63 A/R for the exhaust.
As for the full measurements.. well, that's why I do what I do . I make it efficient for the needs of the motor and consumer.
Old Oct 11, 2005 | 11:20 PM
Maveric's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnByYou &raquo;</TD></TR><TR><TD CLASS="quote">oh how could i be so stupid!
anyways...i tried e-mailing ken at phoenixturbo to talk to him but somethings wrong with the e-mail i guess,it says address not found. so i guess its still 60-1 vs 57 trim.....</TD></TR></TABLE>
Send him a pm his name is phoenixturbo.com on H-T....
if you wanna email him send it to contact@cheapturbo
And to further "elaborate"
the 57 trim is a much better choice for spool your power goals and pocket book....
if you wanted room to grow above 500whp in the future you may want to look into a ball bearing turbo....
Another option is buy the 60-1 you most likely wont be happy with all the lag...but you can "save up" and buy the new ball bearing upgrade later on and still have enough room to grow
Old Oct 12, 2005 | 03:19 AM
Theshodan,could you hook me up with a turbo efficient for the ls? if so how much and what are the specs of the turbo.
ill try to get in contact with ken again,see what he says.
T9U4ReBgO
Oct 31, 2007 09:11 PM
LsturboCRX
May 27, 2005 11:53 AM
ThrowSomeDs
Dec 15, 2004 07:46 AM
LINT
Jun 19, 2004 07:27 AM
HybridCoupe
Jul 17, 2002 03:38 PM
