rod,piston,ring upgrade for boost???
Old May 24, 2007 | 07:05 AM
mikeycivic's Avatar
Default rod,piston,ring upgrade for boost???
Ok guys I am near having my turbo kit complete. I may have some extra money to spend and I ws wondering how beneficial would it be to upgrade my pistons,rings,rods for more reliable boost. I dotn have the $$ to do a full bottom end build so it would basically be all stock sizes from a b16. What (if any) setup would you recommend. I am not looking for crazy HP ut I want more reliable. I know the b16 can push 300+ all day on stock internals but if I upgraded what would I be looking at HP wise. I wont have any head work done either so is it even worth it? Thanks
Old May 24, 2007 | 07:35 AM
Boostfed's Avatar
New User
Default Re: rod,piston,ring upgrade for boost??? (mikeycivic)
Forged Pistons and rods is definately worth it, they can handle alot more abuse than stock and will handle more power and a sloppy tune or bad tank of gas if that happens. Wiseco Pistons for $475 and Eagle rods for $325 is a good deal to ensure you are safe and not down if you blow something up on stock stuff.
Comes down to your tuner, you won't necessarily make more power with aftermarket BUT have the potential too with more boost and more aggressive tuning than a stock motor can handle
Old May 24, 2007 | 07:40 AM
mikeycivic's Avatar
Default Re: rod,piston,ring upgrade for boost??? (Boostfed.com)
the main thing is reliability and the ability to turn the boost up and not worrying about frying my rings, I have a prety good tuner in mind and will tune on crome. My car is not a daily driver but I need reliablity when boosted
Old May 24, 2007 | 07:57 AM
delslo93's Avatar
Since you live in PA...J-K-Tuning.com ftw!
Old May 24, 2007 | 08:01 AM
Schister66's Avatar
Man U FTW
it is ALWAYS worth it to build the bottom end....it greatly increases your potential to make power....with the stock bottom end, you're basically limited to 350whp or less, but with the built bottom end, people are pushing near 600whp on stock sleeves....
Old May 24, 2007 | 08:03 AM
mikeycivic's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">it is ALWAYS worth it to build the bottom end....it greatly increases your potential to make power....with the stock bottom end, you're basically limited to 350whp or less, but with the built bottom end, people are pushing near 600whp on stock sleeves....</TD></TR></TABLE>
wow
Old May 24, 2007 | 08:50 AM
Boostage's Avatar
350whp sucks sooo much on a street car. and not nearly enough. yeah build 600hp.. no build 750whp for your street car
Old May 24, 2007 | 08:53 AM
mikeycivic's Avatar
Default Re: (Boostage)
well I am really considering it. Wiseco pistons with eagle rods. Can I install those without pulling the whole motor and would I need to get my block honed. It only has 66k on it
Old May 24, 2007 | 09:07 AM
delslo93's Avatar
Default Re: (mikeycivic)
You will have to pull the motor to build the bottom end. You will need to rehone the cylinder walls and to be safe polish the crank. You will also need new bearings. You might also want to get the deck checked for flatness to ensure a good mating of the head and to keep your headgasket from blowing out. You will also want to install ARP headstuds or a similiar aftermarket brand to keep the head from lifting.
Old May 24, 2007 | 09:25 AM
mikeycivic's Avatar
Default Re: (delslo93)
good stuff delslo thanks for the info
Old May 24, 2007 | 04:50 PM
mikeycivic's Avatar
Old May 25, 2007 | 01:37 AM
mikeycivic's Avatar
bumpity bump
Old May 25, 2007 | 05:33 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">
350whp sucks sooo much on a street car. and not nearly enough. yeah build 600hp.. no build 750whp for your street car </TD></TR></TABLE>
Meh....i'm at 306 and its a good amount of power to have on the street...i already need to run my Drag Radials all the time if i want traction.....i think that 600whp would be way overkill...my goal is a good 400whp but i want quick spool...
Old May 25, 2007 | 05:35 AM
mikeycivic's Avatar
i want closer to 400 + I know I wont use 600+ whp on the street LOL but it would be nice to have.
bosstedb18b
Feb 27, 2010 04:23 AM
civic_66
Oct 24, 2008 03:24 PM
crxnonvtec
11
Apr 26, 2007 09:38 AM
CarAudioPro
Dec 6, 2005 09:37 PM
1.8T_EG
Apr 2, 2003 02:54 PM
