Safe to run without the Greddy Blue Box
I have a greddy turbo kit ready to install. Do I need to install the blue box if I have a MSD retard system and a VAFC? If I do need it even with the 2 items I have, what does it exactly do?
blue box is a Fuel management unit. IT dumps a lot of fuel into your stock injectors so you don't detonate or blow up the engine when it hits boost.
You can throw away the blue box and run the VAFC Hack with bigger injectors (this is what i'm doing) Just search VAFC hack you'll finds tons of info
you need something to hide the map sensor if you don't use the hack. even if you use the vafc with stock injectors and raise the fuel you'll get a cel b/c the vafc doesn't block the map sensor like the blue box does
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOSEPH »</TD></TR><TR><TD CLASS="quote">get rid of the rest and just use the blue box. Its alot better the the afc hack.</TD></TR></TABLE>
explain how this is so?
how do you tune a rising rate regulator?
personally i would not run the hack. i would run the votech fmu and a missing link on the map sensor for now. and retard your timing with the btm.
i am uncomfortable with the way the blue box dumps fuel. for some reason it seems like it dumps way too much. and for this reason with stock timing people are losing compression....i dunno thats just me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR »</TD></TR><TR><TD CLASS="quote">how do you tune a rising rate regulator?</TD></TR></TABLE>
you cant. I was referring to the afc hack
boostincoupe
Jul 7, 2003 01:12 PM
