Safe to run more boost?
Old May 30, 2005 | 10:50 AM
TeGrSTuRbO's Avatar
Default Safe to run more boost?
Hi I just bought a 1990 Integra RS with a T3/T4b turbo on it. It is a B20B Block with a RARE P8R head and it is currently only running 5psi. i was wondering if it was safe to run more boost?
Albert
List of Specs:
T3/T4b trim .50 A/R
Blox Manifold
Blox FMU
Tial 35mm Wastegate
Tial 50mm BOV
FMIC
2.25 IC piping
MSD inline fuel pump
2.25 downpipe
6 lbs. of boost
B20B block
RARE P8R head
Skunk2 intake manifold
B16 tranny
8.5 lb flywheel
Heavy duty clutch
AEM fuel rail
B&M reg.
Old May 30, 2005 | 11:14 AM
pv2dickman's Avatar
Default Re: Safe to run more boost? (TeGrSTuRbO)
if you were going to boost more i would suggest in getting some better fuel management.. uberdata, hondata, ems ...ect
the most i would personally do with that setup is 10psi.. and even still that is pushing it
Old May 30, 2005 | 11:17 AM
11SEC CIV's Avatar
Default Re: Safe to run more boost? (pv2dickman)
leave it alone until you get some bigger injectors
Old May 30, 2005 | 11:30 AM
TeGrSTuRbO's Avatar
Default Re: Safe to run more boost? (12SEC CIV)
ok...i looked on hondata and i have no idea what to get or anything so can anyone help me with that?
Old May 30, 2005 | 01:18 PM
B20luda's Avatar
not sure what ecu your using but u will need an OBD1 ecu from any obd1 civic integra etc. vtec or not, get it chipped and purchased hondata there should be info on the website about useable ecu's etc, its really not that hard to do..u will also need bigger injetors and someone to tune the EMS
black_ek
Mar 7, 2007 06:07 PM
FrOsTwHiTeDC4
Aug 2, 2005 02:28 AM
TeGrSTuRbO
Jun 8, 2005 06:48 PM
bk11383
Jan 18, 2005 02:42 AM
Smooth-GSR
Mar 26, 2004 11:14 AM
