Safe HP Range
Old Feb 14, 2009 | 07:55 AM
lsdb1's Avatar
Default Safe HP Range
Im building a GT35 LS VTEC
B16 head
ITR or CTR cams
Supertech valvetrain
GE gears
Edlebrock IM
AEM fuel rail
1000cc injectors
68mm TB
B18a Block
Darton MID sleeves
Not sure what piston/rod combo yet but it's gonna be 84mm 9.0:1
micropolished and knife edged crank
GT35r turbo ***only thing is the hot side was changed but i was told it was rated for the same power as a factory GT35r**
I still have to buy the rest of the turbo setup, clutch, ecu and software but it's just a generalization of the hardware i'll have. I want to know what kind of power i can make safely on 93 octane with this setup....I want to be WELL over 400 whp and some decent torque input is appreciated guys thanks
Old Feb 14, 2009 | 08:13 AM
accord_raffi's Avatar
Default Re: Safe HP Range
I tend to stick to accords, but I think it's time I start looking more into the b/d series. Anyways, I know that turbo will definitely be in its efficiency range above 400hp. So far it sounds like you have a build that will give you the numbers you want. I'm curious though...is an ITR cam really worth it on this build? Did you consider a turbo cam? I know bisimoto makes them for f-series. I'm just curious. I could be completely wrong so please inform me.
Old Feb 14, 2009 | 08:33 AM
lsdb1's Avatar
I was just going with the ITR cams because it's a little cheaper than aftermarket (well at least for me) and it'll provide me the extended RPM range for the turbo that i have but i might as well look into aftermarket cams i guess lol
Old Feb 14, 2009 | 09:04 AM
418whpturboD's Avatar
itr cams and ctr cams are really goo for boost.. if you have the suporting mods you could make over 600.. id say go for like 425 on pump..
Old Feb 14, 2009 | 09:11 AM
lsdb1's Avatar
yeah that's what im lookin for, to be able to run on pump gas as a DD
Old Feb 14, 2009 | 09:19 AM
HiProfile's Avatar
Despite this thread being borderline bench dynoing, I'll still endulge you.
GT30 making 530whp with the .82AR housing on a 2.0L:
http://forums.evans-tuning.com/viewt...hp?f=38&t=5105
In the end its up to YOU to determine power levels. A quick glance at the turbo's ratings will give you rough estimates on a horsepower ceiling.
Old Feb 14, 2009 | 12:02 PM
well it sounds like this will be a really nice build. keep us posted!
Old Feb 14, 2009 | 12:04 PM
lsdb1's Avatar
Thanks....that's very very similar to the setup i'll be running but the compresser housing on mine is a .70 A/R ...don't know how much of a difference it's gonna make
Old Feb 14, 2009 | 01:45 PM
b_series_power's Avatar
over 400whp is pretty achievable and safe with those mods and turbo with a good tuner
Old Feb 22, 2009 | 10:23 AM
1lsvtecturbo1's Avatar
New User
whats a good turbo to get 400 + hp with ls/vtec that doesnt take to long to spool?
Old Feb 22, 2009 | 05:16 PM
EARLdaSQUIRREL's Avatar
official honda whore
gt30r easy
op, your setup is very similar to mine and im looking to get near 500whp on 93 oct
ej1bseries
Oct 6, 2012 07:57 PM
greenbeast08
Apr 1, 2012 07:35 AM
MShonda
Jun 27, 2010 05:34 PM
Fixxe2
Jan 4, 2006 12:23 PM
qcktegls
Nov 5, 2004 11:09 AM
