Broken bolt =(
Old Sep 5, 2003 | 01:13 PM
Infinity_Racer's Avatar
Default Broken bolt =(
Well i havent had any luck for the past 2 weeks and this just added to my troubles. As i was putting my car back to stock, i was looking around my t3 and was looking to where oil could be leaking from and going on my manifold, causing smoke to engulf my engine bay when moving. I started checking the bolts and noticed that two of them were loose. The two were the small bolts in the middle section holding the backplate to the compressor wheel.
Well, thinking that was the problem, i overtightened one of them and snapped it. Its the four 10mm bolts, if people dont understand what i'm saying. So after much cursing and yelling, i remembered that i had a screw extractor, but there was no way to get to the screw without having to take the turbo apart. I took my compressor housing off and took the remaing three 10mm bolts off. Still no luck getting to it unless i take the shaft off. BUT i noticed that the wheel is a lot harder to turn now. SOO, can anyone help me out as to take it apart and get the wheel to spin freely?
TIA for any help you can give me....
<~~ Wishes he never sold the greddy kit
Old Sep 5, 2003 | 03:48 PM
Default Re: Broken bolt =( (Infinity_Racer)
toptop
Old Sep 5, 2003 | 05:27 PM
Jared's Avatar
Do you have any pics of what you're talking about?
Old Sep 5, 2003 | 06:06 PM
not actual pic cus i dont have my digi cam...its the bolt right behind the oil drail flange area that connects the center section to the compressor...
Old Sep 5, 2003 | 06:59 PM
Bailhatch's Avatar
I would guess that the housing is just unseated and cocked to one side. That could be why the wheels don't spin freely. Once it is all reassembled it should be fine. Try tapping the housing lightly to seat it while you put it back together.
Old Sep 5, 2003 | 07:16 PM
Default Re: Broken bolt =( (Bailhatch)
i'll try that...hopefully i can find a way to take this bolt out...is there a way to take the compressor fins/blades off of the shaft?
Old Sep 6, 2003 | 03:57 PM
Jared's Avatar
Are you sure you can't get the compressor housing off without taking the wheel off? Everyone I've seen , you could take the compressor housing off the backplate and leave the wheel on.
Old Sep 6, 2003 | 10:39 PM
Default Re: Broken bolt =( (Jared)
naw i got the compressor housing off...its just the other part of it that i need to take off....the part where the center section bolts up to..i'll take pics tomorrow...
Old Sep 7, 2003 | 07:41 PM
well i got some pics...not the best quality but hopefully it'll clear things up...
the bolt is inside the hole of the center section that bolts to the compressor side...
Behind this are 4 bolts connecting the center section to it...one of them is broken and i dont know how to get to it unless i can take the blade/shaft off?
Old Sep 7, 2003 | 07:59 PM
Jared's Avatar
ah, i see now. you're definitely gonna have to take the wheel off to get that.
Old Sep 7, 2003 | 08:11 PM
Foozball26's Avatar
those wheels are balanced, so if you take it off you'd either need to get it re-balanced or get a new shaft/wheels
Old Sep 8, 2003 | 08:14 AM
Default Re: Broken bolt =( (Foozball26)
so basically i cant take it off without having it rebuild/re-balanced? dang, i guess i'll just get it rebuilt, unless i find a cheaper t3 somewhere...
Old Sep 8, 2003 | 09:15 PM
anyone have a decent condition T3 they want to sell for fairly cheap?
Eli_Vang, i responded to your email..
Old Sep 9, 2003 | 08:49 AM
Jared's Avatar
friend of mine wants 400 for a two year old t3/t04b. has about 6k on it.
Old Sep 9, 2003 | 08:56 AM
PeakBoost's Avatar
B*A*N*N*E*D
you must remove the comp wheel to remove the backplate. they are correct, the wheels are balanced and must be rebalanced when reassembled.
the backplate holds the thrust bearing in place. it sounds as if the thurst bearing is out of place and somewhat riding on the shaft(slowing movement) from the backplate being loose.
hope this helps.
InTraining124
Dec 9, 2008 07:39 PM
pro547
Jun 20, 2005 12:54 PM
RNPoo7
Jan 7, 2005 09:54 PM
89 CRX SI
Apr 10, 2003 08:22 PM
DigitalFusion
Jun 19, 2002 06:06 PM
