SAFC Hack Past 11psi
Old Apr 1, 2003 | 03:54 PM
Accord94DX's Avatar
Default SAFC Hack Past 11psi
SAFC
450cc DSMs
Walbro 255lph pump
12-13psi goal.
What do I need to add to enable this to work past 11psi? Just the GM 3bar map sensor? Is there a website or something I can check out? Linky links?
thanks fellas.
Old Apr 1, 2003 | 06:17 PM
Accord94DX's Avatar
Default Re: SAFC Hack Past 11psi (Accord94DX)
would joo prease help me? I'll owe you a burrito
Old Apr 1, 2003 | 06:27 PM
UberTeg's Avatar
jo0 need a 3bar map sensor, but runnin that much boost on the stock sized fuel maps isnt a very good idea
Old Apr 1, 2003 | 06:37 PM
Accord94DX's Avatar
Default Re: SAFC Hack Past 11psi (UberTeg)
Yeah, but its an accord. F22b2 blocks are $100 and no one wants em. It would be cool to experiment.
Old Apr 1, 2003 | 06:51 PM
UberTeg's Avatar
stock sized fuel maps, not stock shortblock
Old Apr 1, 2003 | 07:19 PM
Accord94DX's Avatar
stock fuel maps = lean = heat = preignition = "holy **** a piston just shot through my hood!"
Old Apr 1, 2003 | 07:25 PM
UberTeg's Avatar
nonono, stock SIZE fuel maps.... the stock size is only meant for 0 thru 1 bar (atmospheric). With the afc hack, you're makign the maps very coarse, with a 3bar sensor, you're making it cover 3bar instead of 1bar... and to top it off, ,you're using the extreme vacuum section cuz u'll be getting the equivilent of about 70% map cut!
Old Apr 1, 2003 | 09:02 PM
Joseph Davis's Avatar
The stock fuel maps, once altered, would be fine since the Honda ECU interpolates values. To avoid loss of resolution on your MAP input, could I suggest a GM 2 bar MAP which is good to 14.5 psi?
Also, your ignition advance, which is bad enough with the AFC hack and stock MAP, is going to be worse. You really need to be able to alter your stock fuel maps (at which point you can alter your ignition maps for proper retard). Try PMing GimpyAccord or reading up on PGMFI about swapping a P06/P28 into your Accord.
Old Apr 1, 2003 | 09:28 PM
MikeMAN's Avatar
Default Re: SAFC Hack Past 11psi (J. Davis)
2bar = 29 psi
mike
[Modified by MikeMAN, 12:29 AM 4/2/2003]
Old Apr 1, 2003 | 09:50 PM
Accord94DX's Avatar
**** it 10psi it is
Old Apr 1, 2003 | 11:28 PM
UberTeg's Avatar
Default Re: SAFC Hack Past 11psi (MikeMAN)
2bar = 29 psi
mike
The 1st bar is vacuum.. so a 2bar sensor can only read 1 bar of boost....
And joseph, i already talked to him about covnerting, he doesnt really want to. he wants the world of ecu hackign to bend to his whim to hold onto his accord ecu
Old Apr 1, 2003 | 11:41 PM
Sad, the engine isn't going to last long IMEO. There's no way to properly control ignition timing with an AFC hack save via altering ignition tables. BTMs just don't cut it, especially if you stretch the ignition map further with a GM 2bar.
I believe GimpyAccord/Andrew Shinn mentioned PT3 maps being of the incomprehensible variety I found in the USDM PE7, PK2, PK3, and several others... PM him and he'll give you several reasons that I am unaware of why he switched to P28 - he's not a stupid guy and would know.
You might also consider a stand alone at this point. None of the stuff involved is that hard or expensive (I live in the land of $35 P28), but it's a lot to swallow all at once to learn everything involved, and somewhat expensive if you farm some of it out to others.
Old Apr 2, 2003 | 01:45 AM
swlabhot's Avatar
How about getting 500 or 550cc injectors which should allow you do boost a little more?
Tofurky
Feb 24, 2019 06:09 AM
sohc_kuhol
Feb 19, 2008 02:27 AM
97grnrs
Dec 8, 2007 12:46 PM
B18Tahtaras
Jul 7, 2005 12:06 AM
Egone
Nov 19, 2003 06:37 AM
