GM 3bar MAP sensor
Old Nov 17, 2003 | 10:11 PM
Egone's Avatar
Default GM 3bar MAP sensor
if i install a GM 3bar MAP sensor will it trim my fuel to about 40%??? using dsm 390 cc injectors/fields fuel controller
Old Nov 17, 2003 | 10:23 PM
rjardy's Avatar
Default Re: GM 3bar MAP sensor (Egone)
IT wont trim anything to anywhere, you will have to. All it is going to allow you to do is to boost higher.
Rob
Old Nov 17, 2003 | 10:25 PM
BlueSi2k's Avatar
Default Re: GM 3bar MAP sensor (rjardy)
Im pretty sure it will be trimmed because 5v on the 3bar is like 30psi and 5v on the honda map is like 11psi. This is of course only true with a stock ecu. Im not sure exactly how much it trims though. Hope this helped
Old Nov 17, 2003 | 10:41 PM
Egone's Avatar
Default Re: GM 3bar MAP sensor (BlueSi2k)
well reason i ask is because im getting a fields afc for dirt cheap but it will only adjust the fuel up to 30% which i heard with 390 will make my car hella rich if the gm 3bar doesnt work then im not going to bother with the fields
Old Nov 18, 2003 | 09:21 PM
Egone's Avatar
ttt
Old Nov 19, 2003 | 05:26 AM
steroidguy's Avatar
The gm 3bar map sensor puts out about half of the voltage that the stock honda map sensor puts out. So when you use the gm sensor it is supposed to cut the duty cycle of your injectors in half. This allows you to idle good. Then when you boost you can use you fuel controller to increase the fuel your injectors put out. Somebody correct me if my tid-bit is wrong. sean
Old Nov 19, 2003 | 06:37 AM
Muckman's Avatar
Moderator in Chief
Default Re: GM 3bar MAP sensor (steroidguy)
you mean at the same pressure, it outputs about half the voltage...
B16Civic93
Apr 2, 2005 09:39 AM
fastludeh22
Oct 31, 2002 07:04 AM
DIRep972
Mar 11, 2002 07:01 PM
carolinaACCORD
Dec 9, 2001 08:47 AM
austrian type-R
Sep 1, 2001 05:16 PM
