RWD H22 project has commenced
Old May 17, 2004 | 12:58 PM
  #1001
BlownVR's Avatar
Default Re: (crxandy)
this is one incredible car. keep the pics coming. also nice srt4 project! bumpizzle
Old May 22, 2004 | 12:26 PM
  #1002
itsJDMyo's Avatar
Default Re: (CivicVXHatch)
bump! first time i've ever seen a del sol with an engine in the trunk!
Old May 22, 2004 | 01:19 PM
  #1003
G
sh!t happens.
Default Re: (b00st)
i want to see this thing go.. how much longer
Old May 24, 2004 | 06:05 AM
  #1004
Tinker219's Avatar
Default Re: (G"UNIT)
Im taking two weeks of in July for a Vacation...my "vacation" will be spent in the shop finishing this bastard of wasted space(maybe if I treat it badly, itll conk me on the head and tell me I dont need sleep, finish it!).
Im not even sure what it could cost to have this done...$65 an hour shop rate, Ive got around 80 hours into it so far. I take cars/engines in-trade for labor though!
Old May 24, 2004 | 10:16 AM
  #1005
tunedbylorange.com's Avatar
Default Re: (Tinker219)
can't wait to see this beast driving
Old May 24, 2004 | 10:43 AM
  #1006
vtecdelly's Avatar
that thing is so bad *** its not even funny... just one question about the cage... shouldn't the cross bar behind the seats be higher up so that the harness does not compress your spine....i am in no way dissing this work because it is super cool ,,, just questioning what i have always been told.. also because i want to put a harness bar in my sol and looking at the crazy fab work going into this one for ideas thanks
Old May 24, 2004 | 10:50 AM
  #1007
G
sh!t happens.
Default Re: (vtecdelly)
i cant wait to see the car done and the times it makes rwd honda
Old May 25, 2004 | 04:49 AM
  #1008
Tinker219's Avatar
That crossbar was placed mainly for a "firewall" location. I may end up welding in another round Xbar just for the harnesses. That, and the seats that are in there will not be there when I drive the car for the first time. They are too tall, and I value my head too much to slam it on the over-head bars over every bump.
Old May 25, 2004 | 09:12 AM
  #1009
vtecdelly's Avatar
aghh i see so bad ***
Old Jun 3, 2004 | 06:30 AM
  #1010
Tinker219's Avatar
just keeping the thread alive, from July 1st to July 14th, this car will be completed Except now Im thinking about K series. If I were to get a Haasport mount kit for an EG civic, it would bolt right in...
My only tough spot is management, Im not sure what I would have to do to tune the SpeedPro to function, ie, crank triggers, etc. Can anyone shed some light on this?
Old Jun 3, 2004 | 07:22 AM
  #1011
Jon V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">just keeping the thread alive, from July 1st to July 14th, this car will be completed Except now Im thinking about K series. If I were to get a Haasport mount kit for an EG civic, it would bolt right in...
My only tough spot is management, Im not sure what I would have to do to tune the SpeedPro to function, ie, crank triggers, etc. Can anyone shed some light on this?</TD></TR></TABLE>
Try going to K20a.org they have a lot of k-series info and I'm sure they would love to take a look at your little project
The whole site is dedicated to K series hybrids
Old Jun 3, 2004 | 01:08 PM
  #1012
RaceCity_USA's Avatar
Banned
Im not even sure what it could cost to have this done...$65 an hour shop rate, Ive got around 80 hours into it so far. I take cars/engines in-trade for labor though! </TD></TR></TABLE>
Thanks for your feedback. I admit ignorance of the forum etiquette and would not have posted my request had I known it might elicit a "go somewhere else" response. I apologize for that When I have some pics to post, I'll start another thread for my project.
I would be very interested in how you plan to setup the rear suspension geometry. What specs are you planning to use for camber, camber gain, roll center, and anti-squat? How much scrub radius do you think will work? I'll be using an H22 in my project also and wonder if you have some ideas about spring rates. Are you planning any front suspension geometry changes to compensate for anti-dive and roll axis? I would welcome any discussion on these and other suspension parameters.
Thanks,
Dave
Old Jun 4, 2004 | 07:01 AM
  #1013
kb58's Avatar
Banned
Default Re: (RaceCity_USA)
For the suspension, it all depends what car you're talking about. Spring rates depend upon usage and vehicle weight. There is no one correct answer.
Everything I read says, after much discussion, that anti-squat is a bad idea because it binds the pivot points.
Regarding scrub radius, I think he's using stock front uprights at the back, if so he has negative scrub radius (at least most FWD cars do.) FWIW, scrub radius at the back isn't an issue whether it's there or not.
Lastly, though I'm using an H22 in my mid-engine Mini, I too have been tempted by a K-series engine. I'm old enough to know better though, that I must finish it as is and get it on the road. Tinker, I suggest you do the same to minimize the number of variables. Get it done, drive it, then think about changing it more.
Old Jun 4, 2004 | 08:56 AM
  #1014
Jon V's Avatar
Default Re: (kb58)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 &raquo;</TD></TR><TR><TD CLASS="quote"> I must finish it as is and get it on the road. Tinker, I suggest you do the same to minimize the number of variables. Get it done, drive it, then think about changing it more. </TD></TR></TABLE>
Smart Man
I would still love to see a K series in there though
Old Jun 9, 2004 | 03:42 PM
  #1015
mrehagencivic's Avatar
Default Re: RWD H22 project has commenced (Tinker219)
uhhhhhh.................what can i say..........................bump?
Old Jun 10, 2004 | 04:02 AM
  #1016
Tinker219's Avatar
Default Re: (kb58)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 &raquo;</TD></TR><TR><TD CLASS="quote">For the suspension, it all depends what car you're talking about. Spring rates depend upon usage and vehicle weight. There is no one correct answer.
Lastly, though I'm using an H22 in my mid-engine Mini, I too have been tempted by a K-series engine. I'm old enough to know better though, that I must finish it as is and get it on the road. Tinker, I suggest you do the same to minimize the number of variables. Get it done, drive it, then think about changing it more. </TD></TR></TABLE>
lol, T-minus 3 weeks and counting until thrash time(I cannot wait). Yes I agree with you, get it running first, then move on(which I AM planning on K series swap).
As for scrub radius and suspension garble...if it works, why change it? That, and I admittingly am STUPID when it comes to designing complicated moving parts(ok, and simple). Fixed, solid things I do great with, but moving parts that hold a 2500lb car AND me off the road...I do not have the cah00nas to try that(kb58, this is why your website is in my signature...lol).
As for Camber/toe, I just made slotted upper control arm mounts that allow me to move the upper control arm in/out. Seems to work well in the garage, but not sure when Im 1.2 Gs into a corner We'll know soon enough!!!
Old Jun 10, 2004 | 06:40 AM
  #1017
HaTcH_BmX's Avatar
sell the speed pro and get hondata, k-pro is the way to go with k-series !!
Old Jun 13, 2004 | 09:32 PM
  #1018
Blind-Fashion's Avatar
damn speed BUMPs
Old Jun 21, 2004 | 09:03 PM
  #1019
Rev-Olution's Avatar
anything new?
Old Jun 22, 2004 | 04:04 AM
  #1020
Tinker219's Avatar
Default Re: (Rev-Olution)
13 orders left, 8 days left in June. Looks like my project starting date will be delayed 5 days or so, as I can only get 1 order per day out.
Old Jun 22, 2004 | 04:09 AM
  #1021
99blackcivicSi's Avatar
Default Re: (HaTcH_BmX_Ep3 kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HaTcH_BmX_Ep3 kid &raquo;</TD></TR><TR><TD CLASS="quote">
sell the speed pro and get hondata, k-pro is the way to go with k-series !! </TD></TR></TABLE>
I totally disagree, if you call Speed-Pro and ask them waht they can do for you if they con modify your exisiting system and make a new harness for you i would go with that, IMO i do not like hondata and F.A.S.T. is a FAR superior system to Hondata.
Old Jun 22, 2004 | 04:49 AM
  #1022
Tinker219's Avatar
Default Re: (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">
I totally disagree, if you call Speed-Pro and ask them waht they can do for you if they con modify your exisiting system and make a new harness for you i would go with that, IMO i do not like hondata and F.A.S.T. is a FAR superior system to Hondata.</TD></TR></TABLE>
If I sell the FAST, you can come help me wire the bitch up! As it sits w/the FAST, I only have to run the starter/alternator wires from the engine bay to the trunk. W/the Kpro...uh damn. Not only will I have to wire in an RSX cluster, but then run all the wires back to the trunk. No thanx! Oh ya, if I were to go w/Kpro(not likely), I would put the FAST on my SRT4 and really make some power
This is 22 psi, 92 octane:
Old Jun 22, 2004 | 05:21 AM
  #1023
wow, the neon made awesome power, sorry about your SC61 though that sucks.
Wire up what my F.A.S.T. system was already wired for me thanks to thier harness
I will come up if you pay for gas or a plane ticket kinda long way from Va
Old Jun 22, 2004 | 10:40 AM
  #1024
Tinker219's Avatar
I already have a harness for the FAST too. I was talking about the K-Pro wiring...thats what would suck *****.
Old Jun 22, 2004 | 02:47 PM
  #1025
FunkDaddyFresh's Avatar
that is the most reading i have done in a lo........well ever.. haha
