running very rich with hack.. please help
Old 06-10-2003, 06:26 PM
queez's Avatar
Default running very rich with hack.. please help
hey guys ... doing the hack with 440rc injectors. i have the fuel pressure set around 47psi wth no vacum.. and leaned out 39% - 40% , but i'm still running very rich.. am i doing something wrong??
Old 06-10-2003, 06:42 PM
civperc's Avatar
Default Re: running very rich with hack.. please help (queez)
have you checked out http://www.thedropshop.tv/vafc.htm ?
Old 06-10-2003, 07:51 PM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by queez &raquo;</TD></TR><TR><TD CLASS="quote">hey guys ... doing the hack with 440rc injectors. i have the fuel pressure set around 47psi wth no vacum.. and leaned out 39% - 40% , but i'm still running very rich.. am i doing something wrong??</TD></TR></TABLE>
might try -45%. i was running -40% but when i hopped on the dyno, the engine was running VERY rich. when the tuner leaned it out to -45%, the a/f rose to about 12:1.
Old 06-10-2003, 08:01 PM
vha27's Avatar
Default Re: running very rich with hack.. please help (Daniel)
using dsm 450's at about -35 all over, fpr set at 38 psi, still running rich
id suggest turnig down the fuel pressure to at least 40 psi
Old 06-10-2003, 08:49 PM
Type-GS-R-Turbo's Avatar
Default Re: running very rich with hack.. please help (vha27)
are you running an FMU? at full throttle you should run rich btw? are you putting out black smoke?
I'm running RC 440's aswell with a V-AFC and GM 3 bar map on 15 lbs. Works great with an FMU.
Old 06-11-2003, 02:30 AM
queez's Avatar
Default Re: running very rich with hack.. please help (Type-GS-R-Turbo)
i am not running any fmu.. i'll try lowering my fuel pressure..
but i guess since i am running this rich without installing my warlboro fuel pump.. is it a good guess to say i might not need the fuel pump at all??
Old 06-11-2003, 04:08 AM
scttydb411's Avatar
take it to a dyno tuner with wideband. they will adjust it. my settings range from -46 to -49 and still a tad on the rich side.
Old 06-11-2003, 04:52 AM
swlabhot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-GS-R-Turbo &raquo;</TD></TR><TR><TD CLASS="quote">are you running an FMU? at full throttle you should run rich btw? are you putting out black smoke?
I'm running RC 440's aswell with a V-AFC and GM 3 bar map on 15 lbs. Works great with an FMU.</TD></TR></TABLE>
Any probs or issues in installing the 3bar GM to the stock ECU??
Old 06-11-2003, 04:59 AM
NOSED_CRX_VTEC's Avatar
What makes you think your running rich?
Old 06-11-2003, 03:34 PM
queez's Avatar
Default Re: running very rich with hack.. please help (NOSED_CRX_VTEC)
i have an auto meter a/f meter.. it used to run stoich , but now it is pinned rich, and i'm going through gas like crazy
Old 06-11-2003, 03:39 PM
zojirushi's Avatar
if your using the afc, make sure all the settings are right, eg: sensor is pressure and 6 in and 6 out.
Old 06-12-2003, 03:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by queez &raquo;</TD></TR><TR><TD CLASS="quote">i have an auto meter a/f meter.. it used to run stoich , but now it is pinned rich, and i'm going through gas like crazy</TD></TR></TABLE>
I have the same setup as you but i'm using 450 cc inj and a fmu and stock pump.
Got the car on the dyno and I was very lean.
My auto meter a/f gauge was saying very rich.
I'm now going to get a 255lph in tank pump and a b&m fpr.
Get it on the dyno and find out whats wrong.
Old 07-02-2003, 06:53 PM
9200RPM's Avatar
i have a walbro 250 and the pressure from the walbro is too much for the B&M to hold back...ive put two of them on there....
Old 07-02-2003, 11:11 PM
Default Re: running very rich with hack.. please help (swlabhot)
nope. There is a setting in the Apexi that converts the 3 bar signal to the stock honda signal. Read my thread on this exact topic:
https://honda-tech.com/zerothre...30825
Old 07-03-2003, 06:01 AM
VTC_CiViC's Avatar
Check the plugs.. best way to know what the hell is going on.
maxamusprime
01-21-2007 02:30 PM
99TurboFerio
04-07-2005 04:37 PM
quicksol95
02-25-2005 09:22 AM
honda9369
09-22-2004 03:45 PM
deez nuts
12
06-30-2003 01:32 PM
Quick Reply: running very rich with hack.. please help
