running vacuum lines
Old May 9, 2007 | 07:35 AM
93boostludeSi's Avatar
Default running vacuum lines
im in th process of turboing my honda prelude si/vtec does anyone have diagram of were to run the lines or pics? contact me asap p.m. me or robert_tomkiewicz@yahoo.com the lines that run from the wastegate and boost controller and bov, also boost guage.
Old May 9, 2007 | 08:07 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: running vacuum lines (93boostludeSi)
Boost gauge and BOV go to the intake manifold AFTER the TB.
The bottom port on the WG goes BEFORE the TB as close to the turbo as possible. The top port on the WG goes to your BC. And the other port on your BC goes BEFORE the TB as close to the turbo as possible as well. If need need more info, try the little search button at the top left of your page.
Old May 9, 2007 | 08:09 AM
Civicman86's Avatar
they go to a vacuum source. Brake booster line is a good start. Sounds like you needed to do a little more research before diving into the project. Good luck.
dcintegra88
Jan 18, 2010 01:42 PM
95teilhatch
Sep 30, 2007 01:57 PM
draconx
Mar 15, 2006 06:03 AM
jdm-ray
May 15, 2005 09:37 PM
Lenthrax
Jun 14, 2002 11:05 PM
