Running no cat - 2nd O2 sensor CEL - fix for it
Old Nov 4, 2001 | 11:51 PM
degradated's Avatar
New User
Default Running no cat - 2nd O2 sensor CEL - fix for it
I can't find the thread as to where we were discussing this already (actually I believe there were multiple threads)...
Anyway, I was told that by pulling up the second oxygen sensor up inside the cabin, plugging it in and wrapping it in aluminum foil, this would take care of the CEL. I did so, reset the ECU, and I still have the light on. And I double checked that the CEL wasn't for something else, but it was a code 65 still...
BTW, what's the significance of the aluminum foil? I'm not too clear on what purpose it serves..
Anyway, now that this isn't working, how can I take care of it?
Old Nov 5, 2001 | 12:12 AM
smoothludey2's Avatar
New User
Default Re: Running no cat - 2nd O2 sensor CEL - fix for it (degradated)
Put your cat back on....there's no easy way around a secondary O2 sensor other than converting to OBD1. So if you don't plan on backdating your ecm any time soon just put the cat back on. Pulling the secondary O2 sensor and wrapping it with foil only works for certain OBD2's not all. The foil is there to insulate the O2 sensor from the elements and to keep it warm as if it were still in the cat. The O2 sensors operate on heat...if it's too cold then that might throw you a code.
Old Nov 5, 2001 | 01:28 AM
Anthony K's Avatar
New User
Hmmm, why don't you try resetting the ECU again.
Old Nov 5, 2001 | 02:57 AM
JM Performance's Avatar
Default Re: Running no cat - 2nd O2 sensor CEL - fix for it (Anthony K)
Take a look at this: http://www.jdmfan.com/technical/perf...sor_simulator/
pumpkyn
Jan 30, 2006 11:59 PM
Pariah
Jun 17, 2005 10:24 AM
sfgiants11
Jun 5, 2005 07:22 AM
Nero2007
11
Jul 28, 2004 04:22 PM
HYREV2NR
May 13, 2004 11:52 AM
