Running Lean on Turbo
Old Apr 3, 2003 | 08:45 AM
incognitoracerr's Avatar
Default Running Lean on Turbo
Guys, I installed my turbo a few weeks ago and my fuel ratio is still lean...well before I installed the turbo i ran lean anyway. i would only read stoich when i accelerated...i cleaned the injectors...i use either 93 or 94 octane and still read lean. The problem is...i can't seem to get a stoich reading at idle...when i drive or there is load on the engine i get a mixture of lean and stoich but never just stoich...and when i do get that mixture of lan and stoich the gauge is fully reading lean and just has 3 bars on stoich....what could this be...how can I fix it...will this affect my turbo...i mean i boost fine but I don't want to blow my motor up...help
Old Apr 3, 2003 | 08:47 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: Running Lean on Turbo (incognitoracerr)
What type of FMU? injectors? Fuel pump?
Old Apr 3, 2003 | 08:50 AM
Default Re: Running Lean on Turbo (integra707)
stock everything...but this has been happening before the turbo setup...and fmu is blue box
Old Apr 3, 2003 | 10:18 AM
dfoxengr's Avatar
u need bigger injectors
Old Apr 3, 2003 | 10:23 AM
EG9turbo's Avatar
Default Re: Running Lean on Turbo (hybridvteceg)
Retard your timing.
Old Apr 3, 2003 | 10:29 AM
technine's Avatar
Maybe your a/f gauge is hooked up wrong or a bad power and/or ground. Don't use the stereo wires to hook it up because it will give bad readings. When I did I get a wide reading (more LED's lit up at a time). When I hooked it up with its own power and better ground, it gave a more narrower reading (less LED's and seem to be more steady) and it finally read into the rich area at WOT, too.
Old Apr 3, 2003 | 10:32 AM
93dx--hatch's Avatar
Default Re: Running Lean on Turbo (technine)
what kind of wires should you use to hook it up??
Old Apr 3, 2003 | 12:07 PM
Default Re: Running Lean on Turbo (93dx--hatch)
I used gauge wires and I adavanced my timing from 16 degrees to 18. I guess I have to buy some injectors to see what happens next...the gauge is connected fine...the groud is independent and the positive it right on a fuse...i'll keep you guys updated...thanks...let me know of any other ideas...
Old Apr 3, 2003 | 12:10 PM
TeStUdO's Avatar
well i dont think you should have advanced your timing, and are you using an autometer a/f gauge? you should really get an EGT gauge. also upgrade the injectors. are you using an FMU??
[Modified by 00si5, 1:11 PM 4/3/2003]
Old Apr 3, 2003 | 12:12 PM
Default Re: Running Lean on Turbo (00si5)
i advanced the timing for a little more power...yeah i am using autometer air/fuel gauge...
Old Apr 3, 2003 | 12:15 PM
boosted92's Avatar
First thing you should do use throw that useless light show out. Get a hondata, and take it to a dyno with a wideband O2.
Old Apr 3, 2003 | 12:20 PM
Default Re: Running Lean on Turbo (boosted92)
Yeah I don't think there is any point in the light show...lol...im new to turbo so hold yourself when i ask...whats a wideband o2?
Old Apr 3, 2003 | 12:44 PM
dfoxengr's Avatar
wideband is not just for turbo, its for all tuning apps. it is like your stock O2 sensor except it reads a wider range of voltage hence wideband...more precise reading and allows for better tuning.
Old Apr 3, 2003 | 12:47 PM
Do you know where I can get one for a good price?
Old Apr 3, 2003 | 01:38 PM
Shift!'s Avatar
Hello? Youre running lean, advanced timing is the last thing you should do!
When upgrading your car to a turbo setup you should be going bigger injectors anyways. Try bigger injectors, and doesnt the Apexi V-AFC allow you to manually lean or richen the mixture? THey are like what, 300 bones? That might also be something to consider.
dragonenchantress
May 23, 2004 09:55 AM
honkey2fly
Apr 22, 2004 11:50 AM
jspek29
Jun 10, 2003 05:39 PM
DC2R714
Jul 13, 2002 09:04 PM
ludelvr
Jun 19, 2002 02:53 PM
