RTP Q?
Old Jul 9, 2006 | 03:49 PM
Whiteintegra's Avatar
Default RTP Q?
Can someone please tell me exactly what i will need in order to real time tune. So far ive got this:
Crome
Ostrich RTP From Moates.net
Labtop
Chipped OBD1 ECU.
What else will i need? Are there any cables that i need to get for data logging? How does it all fit together? Is there a faq section about this stuff. TIA!
Old Jul 9, 2006 | 04:12 PM
Turbogixxer's Avatar
Default Re: RTP Q? (Whiteintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Whiteintegra &raquo;</TD></TR><TR><TD CLASS="quote">Can someone please tell me exactly what i will need in order to real time tune. So far ive got this:
Crome
Labtop
Chipped OBD1 ECU.
What else will i need?</TD></TR></TABLE>
Yes, you will need a datalogging cable (serial or USB) plus the drivers to go with it. All but uberdata require you to desolder J12.
Old Jul 9, 2006 | 06:47 PM
so i will have to desolder the j12 wire if im using crome?
can anyone give me more info about how all the wires connect? For example, if i use a plxm300 where exactly do i connect the data logging cables? what goes where?
Old Jul 9, 2006 | 07:08 PM
Default Re: (Whiteintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Whiteintegra &raquo;</TD></TR><TR><TD CLASS="quote">so i will have to desolder the j12 wire if im using crome?
can anyone give me more info about how all the wires connect? For example, if i use a plxm300 where exactly do i connect the data logging cables? what goes where?</TD></TR></TABLE>
I know it is going to sound harsh, but tuning with a DIY software, you will have to do some good research.
Good start: http://www.pgmfi.org/twiki/bin...bHome
Crome forums: http://forum.pgmfi.org/viewforum.php?f=35
http://forum.pgmfi.org/viewforum.php?f=55
But to answer your question, You need to get a USB cable with a convertor. http://www.moates.com sells one with drivers and all. It is called "honda log". You can use cell phone cables, but you have to get teh drivers (simple search can find them). To datalog the a/f in the program, you will connect the 02 output to D14.
Old Jul 9, 2006 | 07:25 PM
jononioo's Avatar
Default Re: (Turbogixxer)
wtf?
Modified by jononioo at 8:25 AM 7/10/2006
Old Jul 9, 2006 | 07:44 PM
Default Re: (jononioo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jononioo &raquo;</TD></TR><TR><TD CLASS="quote">Is this the cable?
http://www.moates.net/usb-20-c....html
If so, do i connect this cable to my computer and the other one to the ostrich?</TD></TR></TABLE>
That is just a USB cable. You need something to convert the data from the ECU to something the laptop can read.
http://www.moates.net/hulog-ho....html
Same thing you have as a pic, but with a black case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jononioo &raquo;</TD></TR><TR><TD CLASS="quote">Here is a diagram of the plxm300. But i don't get how this is integrated into the ECU
You need to set up the setting in crome to diaplay the correct a/f. The wideband output is 0-5v and the narrow band output is 0-1v.
Old Jul 9, 2006 | 09:09 PM
thanks for the quick replies. ok, i think i will be able to understand all this better if i put my hands on everything. can you list exactly what i will need to tune in real time. Thanks!
Old Jul 10, 2006 | 07:16 AM
jononioo's Avatar
sorry to thread jack :/
Old Jul 10, 2006 | 10:23 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Whiteintegra &raquo;</TD></TR><TR><TD CLASS="quote">can you list exactly what i will need to tune in real time. </TD></TR></TABLE>
Aside from a version of Crome that supports datalogging and real time tuning, and the research you've already been told to do? No.
Old Jul 10, 2006 | 10:32 AM
Zakar's Avatar
it does sound like you need to do some more reading before you take the life of the engine in your hands
Old Jul 10, 2006 | 11:10 AM
jononioo's Avatar
Damn, these guys are kinda harsh!
In order to be able to tune, you will need the following
1.)Crome(no datalogging) or Cromepro, hondata, uberdata, turboedit... ect ect
2.)wide band. (tie analog output to ECU narroband wire in order to datalog)
3.)Honda Log/hulog (connects from ECU to USB/serial port)
4.)ostrich for RTP(connects from ECU to USB/Serial?)
5.)Chipped and socketed ECU
6.) Burn 1 Chip burner (Use if you don't want to leave the ostrich in the car)
Please add to the list if im missing anything.
Old Jul 10, 2006 | 12:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jononioo &raquo;</TD></TR><TR><TD CLASS="quote">Damn, these guys are kinda harsh!</TD></TR></TABLE>
The thing is, if (he will) have a problem, he will know how to research the problem and find the answer. The odds are it has been answered before on PGMFI.
That is all
Old Jul 13, 2006 | 10:37 AM
Zakar's Avatar
i wasnt being mean.. i just dont want to see him wreck his ****.. and alot of first timers will give up at that point
Jax99SI
Apr 9, 2008 12:59 PM
NA_EF_8
May 13, 2007 11:46 PM
teler86
17
Aug 14, 2005 05:51 PM
hatchyboy89
Apr 5, 2005 10:20 AM
RTW DC2R
Jun 5, 2002 01:47 PM
