routing coolent lines from turbo problems
Old Jan 9, 2010 | 09:15 PM
cleansi's Avatar
Default routing coolent lines from turbo problems
built gsr block aebs iron sleeves b16 head running 23 lbs on garret gt30r hybrid s300. car was completly tunned and runs like a top
problem is when i go in to boost it over heats waaaay 2 much...
i was told the coolent lines to the turbo are put in the wrong places well the return line it goes back to the im by the thermosta
is that route correct?
what set ups are you guys running ?
thanks for the help i can get pics up if needed
Old Jan 10, 2010 | 12:27 AM
viper_boy403's Avatar
Default Re: routing coolent lines from turbo problems
Just throwing this out there because I'm not familiar with B16's, but on an H22, the temp sensor is right next to the thermostat. So if it's similar on a b16, and you have the return line coming back right by the temp sensor, it will be reading alllll the hot coolant coming out of the turbo, as opposed to the "actual" engine coolant temp
Just an idea
Old Jan 10, 2010 | 12:49 AM
cleansi's Avatar
thanks ,, i was thinkin bout that also, the temp on the b16 head is about 7 inches away in the middle of the side of the head any other opinions?
Old Jan 10, 2010 | 05:01 AM
jjspec's Avatar
Coolant low, maybe a head gasket issue?
Old Jan 10, 2010 | 06:30 AM
YARO.'s Avatar
I run a gsr with a GT3076R and I use the B&R kit. It uses the block for feed and radiator for return. Simple and clean.
https://honda-tech.com/forums/forced-induction-49/turbo-coolant-line-kits-w-black-fittings-2014711/
Old Jan 10, 2010 | 10:37 AM
cleansi's Avatar
head gasget is perfect i run a racing antifreze it helped lower the temp quite a bit its alcohol based yea the coolent was the first thing i checked its fine
thanks ima try 2 find another route for thes dam lines
Old Jan 10, 2010 | 09:45 PM
cleansi's Avatar
bump
Old Jan 11, 2010 | 07:22 AM
darkvader0's Avatar
Where are each of the two ends connected?
I've been thinking about mine. I just took the lines that normally go the throttle body and put them to turbo instead. I'm beginning to think about it and I don't think it's a good idea. I think with it set up like this, coolant comes out of the head and goes thru the turbo... then back into the waterpipe to be pumped thru the block without going thru the radiator.
If yours is like that, I could definitely see it causing problems.
Old Jan 11, 2010 | 07:03 PM
cleansi's Avatar
no my return line goes to the inmanifold write by the thermostate the feed line come from the lower portion of the of the back of the block
thats how the shop build the line connections
Old Jan 12, 2010 | 08:26 AM
darkvader0's Avatar
Hmm... I'd have to see a photo of it to have any more input for this.
Old Jan 12, 2010 | 09:58 AM
hondapowerb16a2's Avatar
i have a 2.0L lsvtec with a top mount gt3076r and I have the coolant lines tee'd off the heater core hoses off the fire wall works great never had a problem.
Old Jan 13, 2010 | 09:33 AM
cleansi's Avatar
is your block sleeved and do you ever read hot when going into high boost?
Old Jan 13, 2010 | 09:43 AM
Yeah its sleeved no cooling problems and it never gets over normal operating temp.
Old Jan 13, 2010 | 03:42 PM
civteck84's Avatar
retorque your head. seen it a few times under long periods of boost your pumping air into the coolent system causing bubbles then you get off boost and temp returns to normal. never comes up on a comp test either. you said your sleeved, but what kind of head gasket? O ringed? what was it torqued to? just my past experiences.
Old Jan 13, 2010 | 09:04 PM
cleansi's Avatar
Exactly!!!! right when i get off boost it imedietly starts to cool down usually after a pass its super hot but when its dne its starts to cool . but also some hot days yes i live in yuma az its still 80's i c it get hot not that the car is adailly driver but we i do tend too take it out more then i should latley
ima get some pics up now of the set up so you H-T guru's (chough) shodan (ehhhaa cough)
can get a lil more of an idea what it might be b4 i decide to pull the cams off to retourqe th
Old Jan 13, 2010 | 09:18 PM
cleansi's Avatar
here a few kinda crappy pics of the set up hope they help
Old Jan 14, 2010 | 04:18 PM
cleansi's Avatar
pics no response?????/
Old Jan 15, 2010 | 04:26 AM
blaze the chemi's Avatar
How does the coolant route through the head once it enters? Does it quickly go by the coolant temp sending sensor for your dash?
I'm more afraid of the hose close to your turbo manifold that would bake and bust fluids all over your bay and cook your turbo.
Old Jan 15, 2010 | 06:38 PM
cleansi's Avatar
well it goes strait to the im in the port on the head but the thermostate,
as for the hose bieng close to the manifold it just looks that way dnt get me wrong it close but the portion is actually wrapped in heat wrap and ive put plenty of time on that hose and i also pre op/check the lines b4 and after becuase of previous leaks
Old Jan 16, 2010 | 05:49 PM
I was asking how the coolant routes through the head upon entering from the IM area above the thermostat. If the coolant gets routed to the coolant temp sensor right away then that would explain why you are seeing a quick rise in temp while boosting.
Old Jan 16, 2010 | 06:30 PM
cleansi's Avatar
yes it does but wouldent that be pouring hot water straight in to the head ?
bad idea huugh?
megomaniac
May 19, 2011 05:57 AM
PINKS
Feb 22, 2007 03:51 PM
Mr HYDE
Oct 2, 2006 06:07 AM
shadowdawn
Sep 30, 2003 11:16 PM
soundman
Apr 22, 2003 08:27 AM
