Round two of my S2000. Step 1 of 3 break in and tune.
Well crud. It has been a very very long time since I have posted anything.
After the Map died we had a sickly motor and only ran to 15psi and made 460whp. We were in the process of checking things out because the car smoked real bad and turns out we had to start over. So here is where we are so far. I will update as we move closer to finishing the break in and into C16 and higher boost.
Right now we are at 12psi and making 430whp on a dyno dynamics dyno. Dyno brand doesn't matter to but what does is that we pulled -4 on the timing from the original set-up and we are 11.2-11.5 till the motor gets some more break in. So for the most part the car is making much better power than it did before. (even if it was broke to some degree)
I still have a inactive PLX a/f gauge that i am working out and just got the temp gauge on the factory cluster up and running again.
So I thought to share were I am the second build around. Looking at more power in a couple weeks once we hit the 1000k mile mark. 17psi is next. 1500 more good miles and c16 and 28psi.
Take it easy
XCAT
Take it easy
XCAT
riceball777
11-18-2012 08:24 AM
yeaitsahonda
Engine Management and Tuning
30
03-22-2012 05:39 PM
