Rough idle and stalling after filling up with gas
Old 01-18-2006, 05:06 PM
PY TYPE R 483's Avatar
Default Rough idle and stalling after filling up with gas
Cliff notes: car is supercharged, and has rough idle after filling up at gas station.
I don't know if its a coincidence, but everytime I fill up my car at the gas station the car does not want to start, and when it does it has a really rough idle and stalls out. At first I thought that I got some water in there since it was raining, then it happened again the next time. Its not the gas station because it happens at different locations.
Any ideas?
Old 01-21-2006, 05:58 AM
Default Re: Rough idle and stalling after filling up with gas (PY TYPE R 483)
any ideas?
Old 01-21-2006, 06:13 AM
Acrappyhatch's Avatar
what kinda fuel pump?
Old 01-21-2006, 09:51 AM
Synapse's Avatar
Default Re: (Acrappyhatch)
I wonder if there's a leak somewhere in your fuel pump assembly? Sounds like air is getting in the line somewhere.
Do you have an inline pump too?
Old 01-21-2006, 10:42 AM
urbansi's Avatar
Default Re: (Synapse)
https://honda-tech.com/zerothread?id=1417163
I had the same problem with this, still do, its annoyinf as hell. It really started one night after i did a compression test on my motor and ever since that day it still does it, and i cant figure out why. Hope this link helps you out
Old 01-22-2006, 08:04 AM
Default Re: (urbansi)
thanks for the input.
the fuel pump is the Walboro 255lph, it only has about 500-600 miles and was brand new when installed. You can hear it whine when I turn the key to the ON position, I do wait a few seconds before trying to start the car after filling up. I never top off the car, and it still has the problem with starting after filling up. I am going to check all the lines for a blockage of some sort maybe?!? But it only does it after filling up, so I really don't think that is the problem...
Old 01-22-2006, 08:10 AM
Man U FTW
Schister66's Avatar
was there a big semi filling the tank at the gas station when you filled?? There is condensation (water) in the tanks and if you're lucky enough, sometimes you get that in your tank....i had a friend that had this happen....luckily he just could run it through and it all worked out for him.......
Old 01-22-2006, 08:11 AM
igo4bmx's Avatar
yeah i had the same problem
are you running obd1 ecu? there is a plug i unplugged on my fuel line and it fixed the problem (it's something that doesn't work on obd1 ecus)
Old 01-22-2006, 08:15 AM
igo4bmx's Avatar
take a look at the middle piece on the fuel rail...
i had to disconnect that and that fixed my problems
Old 01-22-2006, 08:25 AM
Default Re: (igo4bmx)
No, luckily there was no tanker filling the underground tanks at the gas station when I was there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">yeah i had the same problem
are you running obd1 ecu? there is a plug i unplugged on my fuel line and it fixed the problem (it's something that doesn't work on obd1 ecus)</TD></TR></TABLE>
I am running an OBDI ecu, and I never thought that that could be the problem, I will look into that as the problem.... By the way are you on Tri-State as well?
Old 01-22-2006, 08:38 AM
Shmaa's Avatar
Default Re: (PY TYPE R 483)
Do you have an OBD-II car with a P28? or just an OBD-I ecu? Either way try disconnecting your EVAP purge solenoid, just the electrical plug. Should work
https://honda-tech.com/zerothread?id=1411041
Old 01-22-2006, 09:17 AM
igo4bmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PY TYPE R 483 &raquo;</TD></TR><TR><TD CLASS="quote">No, luckily there was no tanker filling the underground tanks at the gas station when I was there.
I am running an OBDI ecu, and I never thought that that could be the problem, I will look into that as the problem.... By the way are you on Tri-State as well?</TD></TR></TABLE>
yeah im on tristate
Old 01-22-2006, 10:58 AM
urbansi's Avatar
I think unplugging the EVAP purge solenoid would work, only problem is i dont know where it is , does anyone have a picture for my dumb ***
Old 01-22-2006, 05:18 PM
urbansi's Avatar
bump
Old 01-22-2006, 08:12 PM
Shmaa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">I think unplugging the EVAP purge solenoid would work, only problem is i dont know where it is , does anyone have a picture for my dumb ***</TD></TR></TABLE>
What car?
Old 01-22-2006, 08:17 PM
Shmaa's Avatar
Default Re: (Shmaa)
I stole a couple of pics.
Old 01-22-2006, 08:44 PM
slowhonduh93's Avatar
does a b16a2 have one and if yes where is it??? thanks alot... im having the same problems but not just after filling up... its all the time... car starts but doesnt idle and no cel...
Old 01-22-2006, 09:29 PM
kameleon23's Avatar
Default Re: (slowhonduh93)
I have a 00 Si, that has a p28 and mine does the same thing. I also have the walbro 255lhp. Im going to unplug the solenoid and see if that works for me.
Old 01-22-2006, 10:36 PM
rhettster's Avatar
Default Re: (kameleon23)
My vote is for fuel filter or bad gas cap.
Old 01-24-2006, 02:29 PM
Default Re: (rhettster)
I unpluged the EVAP purge and filled the car up. I tried to start it right afterwards and it started up no problem, so I am guessing that was the problem. I am going to try to plug it back in and see if it happens again.
Old 01-24-2006, 06:05 PM
Shmaa's Avatar
I think its a problem with the OBD-I ECU not using the solenoid correctly or at all and the gasses get stuck in there or something.
Old 01-24-2006, 06:28 PM
m R g S r's Avatar
Default Re: (Shmaa)
yeh i just ripped all that **** out when i went turbo.....
Michael Booth
01-22-2018 11:26 AM
mlanning
04-20-2015 05:44 PM
fafsa
01-27-2005 10:06 AM
Nick M
01-03-2003 09:05 PM
Quick Reply: Rough idle and stalling after filling up with gas
