car is sputtering on turns?
Old Jan 27, 2005 | 06:09 AM
fafsa's Avatar
Default car is sputtering on turns?
everytime im turning and adding gas as i turn, it starts to "sputter" i dont know a word to explan it. any idea's on what could cause this? also sometimes when i start the car up, it starts up and then rev's just drop until it shuts off, i ussually give it has until the idle goes back to normal.
Old Jan 27, 2005 | 07:08 AM
b18bturbo's Avatar
Default Re: car is sputtering on turns? (fafsa)
whats the fuel level like in the car is it low or high.
Old Jan 27, 2005 | 07:18 AM
fafsa's Avatar
Default Re: car is sputtering on turns? (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">whats the fuel level like in the car is it low or high. </TD></TR></TABLE>
yeah, i was gunna edit and say this, the gas was pretty low. is that the answer to both sputtering and the start up idle problems?
Old Jan 27, 2005 | 07:20 AM
adictionbass's Avatar
Im going to say yes.. When you turn, gas will flow to one side of the tank or the other, the pump is in the middle. I dont know about idle, you'd have to be really low on gas.
Old Jan 27, 2005 | 09:29 AM
b18bturbo's Avatar
Default Re: car is sputtering on turns? (adictionbass)
if that is the case then are you using a walbro pump.
if so are you using one with stock sock or are you using the aftermarket sock that is supplied. They have tendancy to do that. esepcailly when the fuel is low
Old Jan 27, 2005 | 09:57 AM
dornon13's Avatar
i just put my walbro in and it sputters out when i start my car once im down to about 1/4th tank....but it doenst do it every time id say thats your prob if you are running one
Old Jan 27, 2005 | 10:02 AM
fafsa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">if that is the case then are you using a walbro pump.
if so are you using one with stock sock or are you using the aftermarket sock that is supplied. They have tendancy to do that. esepcailly when the fuel is low </TD></TR></TABLE>
do you mean fuel filter? im re-using the oem filter. i didnt use the one walbro provided
Old Jan 27, 2005 | 10:06 AM
b18bturbo's Avatar
yes its the sock filter all you need to do is use the one provided it works a little better than the factory one but it also has to fit correctly into your tank to get the most out of it what hapens it sucking in air when you turning and not the gas like it should causing sputtering.
Michael Booth
Jan 22, 2018 11:26 AM
PY TYPE R 483
Jan 24, 2006 06:28 PM
ans
Jan 1, 2006 05:53 PM
Toe-Knee360
Mar 16, 2005 08:35 AM
