Ringlands cause
Old Jan 27, 2016 | 06:37 AM
GT500FTW's Avatar
Default Ringlands cause
Hey guys
I've managed to destroy the ringlands on 3/4 of my pistons and I'm wondering what the cause could be.
It's a stock B16a2. Stock pistons and rods. Using ARP head studs.
Running at 270WHP at 8psi of boost.
It's got a Walbro fuel pump.
I was at the end of the 1/4 mile, and as soon as I lifted off the gas, I got loads of white smoke from the exhaust. I though it was HG because if the steam, but it turns out to be the ringlands.
Does anyone know what could have caused this?
Old Jan 27, 2016 | 06:45 AM
Schister66's Avatar
Man U FTW
Default Re: Ringlands cause
Could be the tune, but it could simply be bad ringlands. They're a cast piece and known to be failure-prone. Sucks...
EDIT: 3 of 4 is not a coincidence or problem with manufacturing. Tune or fuel-related issue causing lean conditions / detonation
Old Jan 27, 2016 | 07:07 AM
GT500FTW's Avatar
That's what I was thinking. My tuner has a really good reputation, but does use Crome.
I was right at the end of the 1/4 mile, hitting 118mph, and might have buzzed the limiter in 4th a bit. Could hitting the limiter cause this type of detonation?
Old Jan 27, 2016 | 07:40 AM
turbohatch96y7's Avatar
Bad tune breh
Banging the limiter is bad for rods and bearings
I snapped a rod banging the limiter
The ringlands held up fine lol
Old Jan 27, 2016 | 07:41 AM
Ive gotten "tunes" from "tuners" with "good reps"
Lets just say i blow my own motors now
If you have any spark plugs from that motor in good shape or the top of the pistons post em up
Old Jan 27, 2016 | 08:39 AM
GT500FTW's Avatar
No pics of the spark plugs, but when checking them, they seemed fine. Tops of the pistons look fine to me. Sorry i don't have a better photo.
Old Jan 27, 2016 | 09:18 AM
Did it burn oil?
Old Jan 27, 2016 | 09:47 AM
GT500FTW's Avatar
Yeah, it did burn a small amount of oil before it let go.
Video of the exhaust - you can see a bit of oil/fuel burning -
Old Jan 27, 2016 | 10:26 AM
B and B's Avatar
Loved
Community Favorite
Citroen!
That explains 118 trap with 270hp...
What's it weigh? (lbs.)
Old Jan 27, 2016 | 10:44 AM
GT500FTW's Avatar
Originally Posted by B and B
Citroen!
Haha thanks. Yeah i was happy with my 12.81 @ 118.1. Especially seeing as the surface was really poor!!!
That's nothing though, it's currently being converted to AWD. Another B16 turbo for the rear
Old Jan 27, 2016 | 10:51 AM
B and B's Avatar
Loved
Community Favorite
Old Jan 27, 2016 | 11:34 AM
Schister66's Avatar
Man U FTW
I hope you're planning some heat shielding between you and the engine so that when the manifold cracks and falls off, you dont start on fire...
Old Jan 27, 2016 | 11:53 AM
GT500FTW's Avatar
I wouldn't worry about that. I'm over in Scotland. Steel has a different "cracking" temperature over here. Something to do with the gulf stream....don't ask me, I'm not a scientist.
Old Jan 27, 2016 | 04:21 PM
VegaS10's Avatar
wat
Old Jan 28, 2016 | 05:41 AM
Flr Power's Avatar
Originally Posted by turbohatch96y7
Bad tune breh
If your rev limiting strategy is wrong then it can do that.
Old Jan 28, 2016 | 04:27 PM
Aradin's Avatar
Premium Member
Someone please enlighten me. How is limiter bad for rods and bearings exactly? I have never heard that before.
Old Jan 29, 2016 | 07:20 AM
motoxxxman's Avatar
I'd also say it's probably tune related, or could just be from the rev limiter. I use crome in my own car, and have tuned countless cars with it myself. and it works great, IF you know how to work with it, and if you're not looking for any special features. And I can say this; the rev limiter and "launch control" (rev limit) are not the greatest. it's just an ignition cut or ignition/fuel cut. it's not a soft limiter that alters timing a bit too.
The pistons do not look like they've seen much/any serious detonation, but they are quite clean and have a specific color pattern, so that tells me you're running fairly aggressive timing near it's peak performance limit. And this alone can add some stress to the ringlands. I've shattered ringlands on stock pistons in my car from aggressive timing alone. Zero detonation, and hadnt even reached peak output yet, but was close. In my experience, stock cast honda pistons can withstand around 230-250tq with aggressive timing, and up to 350tq with conservative timing, before ringlands start shattering like clockwork
Haha!! I loved this one, actually laughed out loud
depending on how the rev limiter functions (ignition cut, ignition retard, fuel cut, fuel enrichment, etc) it can cause some nasty shockwaves and harmonics through the internals, and sometimes can even cause detonation, and other times can start the combustion process halfway down the stroke which basically hammers the piston with a near explosion
EG-Tuner
12
Sep 25, 2007 03:58 PM
GripDriverEF
Nov 14, 2006 07:54 PM
SoSlo
Jun 10, 2005 01:02 AM
speedtechpa
Dec 23, 2004 07:41 PM
12 oz.
Feb 28, 2002 07:51 PM
