Ring gap D16z6 wisecos
Old Feb 4, 2006 | 03:59 PM
dornon13's Avatar
Default Ring gap D16z6 wisecos
here are the ring gaps i came up with since my spec sheet had nothing on it.
75.5mm bore
top ring- 0.015"
2nd ring- 0.016"
0.015"
do i need to be more precise than that? And do those sound good let me know if i left out anything important
Modified by dornon13 at 4:23 PM 2/5/2006
Old Feb 5, 2006 | 06:42 AM
dornon13's Avatar
Default Re: Ring gap D16z6 wisecos (dornon13)
anyone?
Old Feb 5, 2006 | 06:56 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Can't really help you, but free bump since I plan on doing a Wiseco/Eagle Y8 buildup this summer hopefully
Do you think those specs would apply for a Y8 block as well?
Old Feb 5, 2006 | 07:12 AM
ladysman's Avatar
Default Re: Ring gap D16z6 wisecos (boostincoupe)
This may or may not help. Endyn uses wiseco's.
http://www.theoldone.com/artic...s.htm
Old Feb 5, 2006 | 07:18 AM
dornon13's Avatar
Default Re: Ring gap D16z6 wisecos (ladysman)
hmm thats alot smaller than what i came up with of wiseco's site...im wondering if you should open or close the gap when going FI.
The specs should be the same if the bore is the same...the formula is [bore X (whatever the spec is they give you.)] in inches...
i found:
[Bore X 0.0050] Top Ring
[Bore X 0.0055] 2nd Ring
0.015 min oil ring gap
here is my resource http://www.wiseco.com/PDFs/Cat...s.pdf
Old Feb 5, 2006 | 07:39 AM
sc4dr's Avatar
sounds a little tight? anyone back me?
Old Feb 5, 2006 | 07:52 AM
dornon13's Avatar
Default Re: Ring gap D16z6 wisecos (sc4dr)
mine or endyn's?
Old Feb 5, 2006 | 08:02 AM
seerx's Avatar
I had no problem using wiseco's .0050/.0055 per inch on my z6 last year. Stock block ,eagle rods 22lbs t3 60trim. no smoke and good compression on all four. go by wiseco specs on all their pistons. good luck.
Old Feb 5, 2006 | 08:07 AM
93turbo16's Avatar
I would open them up a little bit. That is a little tight IMO.
Old Feb 5, 2006 | 08:12 AM
sc4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">mine or endyn's?</TD></TR></TABLE>
yours
Old Feb 5, 2006 | 12:58 PM
dornon13's Avatar
well i think im going with
0.017" top ring
0.019" 2nd ring
Old Feb 5, 2006 | 02:36 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">hmm thats alot smaller than what i came up with of wiseco's site...im wondering if you should open or close the gap when going FI. </TD></TR></TABLE>
Higher cylinder temps = open the gap. Nitrous/Supercharged/Turbo always runs wider gaps then NA.
Old Feb 5, 2006 | 05:03 PM
dornon13's Avatar
Default Re: Ring gap D16z6 wisecos (Hybrid93Eg)
thanks good info
dez6
Feb 2, 2009 05:20 PM
myflyintegra
Jan 16, 2009 02:47 PM
G3NR8
Apr 6, 2006 08:08 AM
spun Vtec
Jan 9, 2003 05:47 PM
