PISTON CODE? D16z6 piston code and y8 same?
Old Jan 16, 2009 | 08:38 AM
myflyintegra's Avatar
Default PISTON CODE? D16z6 piston code and y8 same?
What is the piston code for a d16z6 and are the same pistons used in the y8? Please help if possible. Thanks
Old Jan 16, 2009 | 11:48 AM
Default Re: PISTON CODE? D16z6 piston code and y8 same?
Bump
Old Jan 16, 2009 | 12:51 PM
97 ek coupe's Avatar
d16z6 pistons are P28s and y8 use p2ps.
Old Jan 16, 2009 | 12:56 PM
Rapa's Avatar
Codes
Z6
13010-P28-A01(STD)
13020-P28-A01(.010)
13020-P28-A01(.020)
Y8
13010-P2P-000(STD)
13020-P2P-000(.010)
13020-P2P-000(.020)
Old Jan 16, 2009 | 01:13 PM
Another question and its prob stupid question. But can either piston be used in either block. J/w like is one lighter or something. Cuz i think the bore is the same size in both blocks. let me kno. Thanks for helpin out an idiot. lol
Old Jan 16, 2009 | 02:12 PM
Bump-
Old Jan 16, 2009 | 02:20 PM
m_shake's Avatar
http://heeltoeauto.com/httech/YaBB.pl?num=1160787887 GL finding weights
Old Jan 16, 2009 | 02:38 PM
Originally Posted by m_shake
Thanks man, But i guess that the pistons cant be used in either block? Thanks
P2P-000
96-00 EX
D16Y8
total height: 49.25mm
compression height: 29.50mm
2.12mm dish
P28-A01
92-95 EX/Si
D16Z6
total height: 60.00mm
compression height: 30.00mm
3.00mm dish
Old Jan 16, 2009 | 02:47 PM
m_shake's Avatar
as far as i know, all d-series piston's can interchange(99-00 gx pistons have 21mm piston pin, same as LS) check out onecamonly . com you'll find more d-series luv there
Tippyman
Apr 18, 2007 07:25 AM
Everyones Hero
Dec 2, 2005 10:17 PM
eg4usdm
May 8, 2005 12:22 PM
ill_take_one
Feb 25, 2003 12:05 PM
Hybrid
May 27, 2002 04:58 PM
