RHB5 IHI turbo??
Old Mar 30, 2004 | 07:09 PM
AIteg's Avatar
Default RHB5 IHI turbo??
i have a b16 in a 91 integra and i was wondering how this turbo would do with this motor and how this turbo is compared to a t3/t4??? im new on turbos so any help would be appreciated....thanks a lot
Old Mar 30, 2004 | 07:14 PM
ITSTOCK's Avatar
Default Re: RHB5 IHI turbo?? (AIteg)
The ihi rhb5 is a tiny as turbo, smaller then the saab t3's. I would defintley look into getting something quite a bit bigger.
Old Mar 30, 2004 | 07:49 PM
AIteg's Avatar
Default Re: RHB5 IHI turbo?? (ITSTOCK)
thats what i needed to know...thanks
Old Mar 31, 2004 | 10:40 AM
tgreaves's Avatar
I think a bigger T3 or a T3/T4 would work for you..
Old Apr 13, 2004 | 08:03 PM
AF-b16a1's Avatar
what size is that turbo compared to? and anyone have pics
Old Apr 13, 2004 | 08:06 PM
onePOINTsix's Avatar
Default Re: (AF-b16a1)
i have a RHb5 about to go on my car, i'll see if i can snap off some pics compaired to a WRX turbo (only other one i have)
Old Apr 13, 2004 | 08:08 PM
Default Re: (Sideout)
Old Apr 13, 2004 | 08:40 PM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AF-b16a1 &raquo;</TD></TR><TR><TD CLASS="quote">what size is that turbo compared to? and anyone have pics</TD></TR></TABLE>get with me
ill showu a pic
Old Apr 25, 2004 | 09:43 AM
EJ2-Fluffy's Avatar
Default Re: (USDM 4G VTEC)
Taken from Homemadeturbo.com
Old Apr 25, 2004 | 09:47 AM
EJ2-Fluffy's Avatar
Default Re: (CRX-Fluffy)
Whats nice about the IHI is you have a very flat torque line and a good amount of top end power. Plus, Its small and generally gives you a much quicker spool then the bigger ones. Just like any other custom turbo setup, You'll need everything custom made, especially the adapter plate.
Old Apr 25, 2004 | 09:49 AM
Joseph Davis's Avatar
RHB5's vary a little bit. The Scooby ones frm the old RX and wagons you'd be lucky to get more than 150 whp from, the 87-88 Ford unit with the VJ16 compressor may get you to 200.
They are pretty tiny. We have a Scooby RHB5 on the turbo Justy - 70-odd hp 1200cc 3 cyl - and it spools at 3K.
The new WRX ones aren't the RHB5 anymore, but they share the same turbine flange design as the old Scooby. Those are much more efficient turbos and make a bit more power. If you were to run across one of those, it would make for a good streetcar setup.
Old May 3, 2004 | 06:28 PM
EJ2-Fluffy's Avatar
Yes they are different. Im guessing from research this is what it comes down to.
Square Flange = Mazda 626 / Ford Probe
Triangular Flange = Subaru
Old May 3, 2004 | 06:48 PM
MiraiZ's Avatar
Tiny!!!
Old May 3, 2004 | 07:34 PM
blackeg's Avatar
Default Re: RHB5 IHI turbo?? (MiraiZ)
rhb5's are ball bearing and extremely efficient. they are however very small. here is some info on them. fyi- they are the same as rhf5, just older i believe, which is the turbo you should look at for specs. and the flow is in cubic meters/min instead of lbs/min, which pissed me off cause im not good with converting
http://www.ihi-turbo.com/turbo_RHE-RHF.htm
Fo-Do Fanatic
Apr 24, 2008 05:21 PM
slowcrxsib16
Sep 26, 2007 06:00 AM
mrx
Oct 15, 2005 08:32 PM
boostin b16
Apr 17, 2003 02:31 PM
