Revving to 9k?
Old Jan 7, 2003 | 08:05 PM
SiRkid's Avatar
Default Revving to 9k?
Ok boys and gools
ive been wondering about this for the last couple days.since i cant really afford to buy a 1.8 block and build it ill just work with what i have. (b16)
hows about revving to 9k(with itr valvetrain...well at least half of it for me )
with gsr cams .
.82 a/r 60-1 should make power to 9000?
and im sure the rest of the motor can handle those revs.
any thoughts?
Old Jan 7, 2003 | 10:07 PM
*Boostwerks*'s Avatar
Default Re: Revving to 9k? (SiRkid)
your building this motor up arn't you?
Just wondering. I know how you feel right now though....just waiting and waiting for the money and parts to collect so you can start boosting the bad-boy.
If properly built the motor should be fine. I say go for it!
Old Jan 7, 2003 | 10:09 PM
VaporTrail's Avatar
New User
with a proper flowing intake manifold, a .63 a/r 60-1 will flow to 9k. Hell a 50 trim E housing would
Old Jan 7, 2003 | 10:12 PM
LS-hatch's Avatar
Is the bottom end stock? If so will the it be able to handle it?
Old Jan 7, 2003 | 10:42 PM
Speedworks801's Avatar
Default Re: Revving to 9k? (LS-hatch)
I do it daily with Skunk2 springs and retainers and a 60-1 with .63 a/r.. No problem.
Go for it.
Old Jan 8, 2003 | 02:51 AM
turbohonda's Avatar
Default Re: Revving to 9k? (Speedworks801)
I would be skeptical about running boost up to 9000 rpm with a stock bottom end! That turbo will hold boost up to 9000 but I don't know about the stock rods. I guess it depends on how much boost you really want to run?
Old Jan 8, 2003 | 03:03 AM
paulzy's Avatar
buy mine... it's built, it's dirt cheap, and no waiting..plus you will help my hot rod project...
Old Jan 8, 2003 | 03:38 AM
Charlie Moua's Avatar
Default Re: Revving to 9k? (1320development)
hey guys i always thought that REVing only helps if the cams make HP in that rang. I know that in N/A you would only rev to 9k if your cams carried the HP that far.(example: no need to rev to 9k if you LS stops making power at 6700? even if your valvetrain allows you to. RIGHT???)
Old Jan 8, 2003 | 03:45 AM
paulzy's Avatar
Default Re: Revving to 9k? (Charlie Moua)
yeah, but you have the power of positive boost taking care of teh power problem...God I love turbos...
Old Jan 8, 2003 | 04:01 AM
done's Avatar
thats only if your running high boost correct?? i know at 6 pounds your peak power will be at 7800rpms with those cams..
Old Jan 8, 2003 | 07:34 AM
SiRkid's Avatar
Default Re: Revving to 9k? (Jordo)
thanks for the input guys.
i think the stock bottom end could handle it but im not planning to run stock rods etc.
any other info?
Old Jan 8, 2003 | 03:48 PM
SiRkid's Avatar
Old Jan 8, 2003 | 04:45 PM
V-SPEC 1's Avatar
How about a fully built b20vtec turbo, Can I rev it up to 9k? is it safe?
Old Jan 8, 2003 | 04:54 PM
KOTSEMOTO's Avatar
Default Re: Revving to 9k? (boostedb20vtec)
yes, it is safe. it is just a question of reliability. your rod ratios are bad so it wont last as long as the ones with better rod ratio.
Old Jan 8, 2003 | 07:08 PM
SiRkid's Avatar
Default Re: Revving to 9k? (KOTSEMOTO)
what he said but if its built well and tuned well, youll be fine. im planning this on a b16 so .. ya know
Old Jan 15, 2003 | 02:19 PM
93LSivic's Avatar
****, I had my built LS up to 8800 already. 9000 will come when I tune it....although its rich as hell right now.
I say go for it, just be sure to get the motor built and maybe some good ignition components like a coil.
revs9K
Feb 9, 2007 10:53 AM
vtecteg00
Aug 30, 2005 03:03 PM
jdmsijdm
Mar 2, 2005 09:36 PM
1point7T
Jul 7, 2004 06:21 AM
