Revised Compression Numbers
hey guys i re-did the compression test at WOT and got these numbers. my car is a '95 LS with 75K on the block.
CYL 1: 180
CYL 2: 165
CYL 3: 170
CYL 4: 185
someone told me that the center two cylinders are usually lower due to heat that is not dissipated as well as if it were on the two outside cylinders. Jim what do you think? im going to be boosting here soon, and am just checking to see if these numbers are okay?! the honda manual says they are within spec.
[Modified by Jspd, 12:55 PM 3/17/2003]
CYL 1: 180
CYL 2: 165
CYL 3: 170
CYL 4: 185
