ran compression!
Old Jan 7, 2010 | 06:40 PM
vinceiscoo's Avatar
Default ran compression!
ran a compression test today,
hit
120
75
120
130
what the compression of a ls?
Old Jan 7, 2010 | 06:52 PM
cwd14's Avatar
Default Re: ran compression!
I believe it is minimum 140 psi max 200 psi. So you may be in some trouble
Old Jan 7, 2010 | 07:03 PM
GagnarTheUnruly's Avatar
It's more important that the compression be consistent than that it be a particular value. You're dropping a lot on cyl. 2 so you've probably got a leak somewhere.
Old Jan 7, 2010 | 10:27 PM
cwd14's Avatar
I was just quoting from the 1994 integra manual.
Old Jan 8, 2010 | 09:53 PM
vinceiscoo's Avatar
thanks guys!
88 civic
Apr 5, 2009 03:21 PM
puma2132
Feb 8, 2009 02:37 PM
K20 EG
Jun 17, 2003 11:26 AM
