Revhard Maniold problem
Old Oct 8, 2001 | 08:31 AM
Alphahelix's Avatar
Default Revhard Maniold problem
Anyone seen the problem with the revhards; the oil dipstick does not clear the center headbolt/nut. My dipstick is hard to pull thru the space in the manifold. Any ideas for a remedy.
Old Oct 9, 2001 | 01:09 PM
Alphahelix's Avatar
Default Re: Revhard Maniold problem (Alphahelix)
c'mon....please
Old Oct 9, 2001 | 01:22 PM
b18bturbo's Avatar
you need to bend your dipstick tube to the coorect space between the head and the manifold.
Old Oct 9, 2001 | 01:25 PM
Alphahelix's Avatar
Default Re: Revhard Maniold problem (b18bturbo)
You have got to be kidding !!!!!!! How will the reading be true if the pipe is bent ?
Plus, how in holly crappy manifolds do you bend the pipe ?
Old Oct 9, 2001 | 02:55 PM
d mafia's Avatar
New User
I had that same problem with my rev-hard manifold on my B18C1. All I did was to take a pipe of slightly larger diameter and slip it over the dipstick pipe and bend with controlled force.
Old Oct 9, 2001 | 02:56 PM
dbman96's Avatar
New User
Default Re: Revhard Maniold problem (2FAST4U)
The reading will be true because when you bend something you don't change its length.
tuckin' flush
Dec 5, 2012 08:57 AM
weiRtech
Welding / Fabrication
13
Feb 14, 2006 06:01 AM
WillM
Nov 23, 2004 02:57 PM
xpracing
Jan 15, 2003 09:10 PM
