My freaking turbo is put together wrong!!!
Old Oct 9, 2001 | 12:15 PM
chri5's Avatar
Default My freaking turbo is put together wrong!!!
The damn turbo is rotated about 45 degrees too far, and where the turbo is supposed to connect to the IC piping it, instead of going basically straight down, faces backwards into the block. So my qustion is this...what problems would i face if i took the compressor off of the exhaust housing and rotated the turbine one set of bolts? I know it is doable, as that is how it is supposed to be, but would I have to replace any seals or gaskets that I dont currently know about?
Thanks CHris
Old Oct 9, 2001 | 12:23 PM
DirtyLude's Avatar
Default Re: My freaking turbo is put together wrong!!! (Chris_Turbo)
Both exhaust and intake housings are made to be turned in relation to the bearing housing. Just unbolt them and turn them to where they're needed.
Old Oct 9, 2001 | 12:28 PM
91LUDESI's Avatar
New User
what you need to witch is the same thing i had to do is loosen the bolts on the inside flange of the turbo (should be about 6 or so bolts on a metal flange) and then just rotate it to where you need it then tight it back up
98 accord
t3/t4 turbo/intercooler
port/polished head/valves,springs
cam/JE pistons custom rods
and all the electronics you need
Old Oct 9, 2001 | 01:03 PM
chri5's Avatar
Default Re: My freaking turbo is put together wrong!!! (91LUDESI)
kick ***, that is what i figured. Thanks
Old Oct 9, 2001 | 01:04 PM
dustin's Avatar
It is called "clocking" the turbo, and everyone here had to do it
Turbonetics/Garrett had no idea which way your piping would sit relative the center housing.
Dustin
Old Oct 9, 2001 | 02:24 PM
chri5's Avatar
Default Re: My freaking turbo is put together wrong!!! (dustin)
Dustin
damn, anyone know what tq those bolts ont he turbo are supposed to be at?
Old Oct 9, 2001 | 02:26 PM
dustin's Avatar
Not all that tight I do not think. I just used an open end wrench and made them "pretty tight". Probably around 20ft-lb
Dustin
Old Oct 9, 2001 | 03:03 PM
chri5's Avatar
Dustin
just my style. I didnt use a torque wrench on a single thing in my JRSC install or uinstall. "pretty tight" it is.
hastingsr
May 5, 2009 03:01 AM
l2yanE
Aug 24, 2005 11:44 PM
TurbothisLS
Feb 19, 2004 05:53 AM
youngkow
Jan 3, 2003 12:03 PM
Tofurky
Dec 7, 2002 04:48 PM
