reusing a ACT xtreme pressure plate
Old May 30, 2006 | 11:11 AM
komat's Avatar
Default reusing a ACT xtreme pressure plate
i was wondering if its ok to reuse the ACT xtreme pressure plate that has 6000-7000 miles on it. it never saw the drag strip or seen any high rpm clutch drops.
heres a pic what it looks like right now.
if i were to reuse it , it will have a new 6puck spung disc and the flywheel will be resurfaced
Old May 30, 2006 | 11:38 AM
rmcdaniels's Avatar
Default Re: reusing a ACT xtreme pressure plate (komat)
I reused mine with twice that many miles and a whole lot of drag strip launches. It worked fine. I didn't even resurface the flywheel, just put a new 6-puck disk in it and went.
Old May 30, 2006 | 01:43 PM
komat's Avatar
Default Re: reusing a ACT xtreme pressure plate (rmcdaniels)
how did your pressure plate look?
Old May 30, 2006 | 03:23 PM
Mugencrxsir1's Avatar
That pressure plate is fine, reuse it. ACT pressure plates are tough as hell, and can with stand a lot of abuse, and are usually heavier than most apps need. I've reused mine twice without a problem, reuse it
Old May 30, 2006 | 04:35 PM
komat's Avatar
Default Re: reusing a ACT xtreme pressure plate (Mugencrxsir1)
alrite thanks!
Old May 30, 2006 | 04:46 PM
crazy_eddy's Avatar
hi guys
To all who are using the ACT xtreme PP how havier oes the clutch pedal feel with the ACT i have a Exedy stage 1 right now and want to change it soon.
any input would be great
Thanks
Old May 30, 2006 | 04:50 PM
komat's Avatar
Default Re: (crazy_eddy)
from stock
its alot heavier
takes about a week to get use to it
Old May 30, 2006 | 05:08 PM
BoostedGreddy's Avatar
How strong is the centerforce Pressure plates? i might be re-using mine... ne one have experience?
Old May 30, 2006 | 05:34 PM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">how did your pressure plate look?</TD></TR></TABLE>
A little chewed on, but not too tore up.
Old May 30, 2006 | 05:55 PM
HamiltonRex's Avatar
Re-use it...
It will be fine, ive got an organic disc with the street plate, boosted b18c, seen much track time/abuse, holds good.. In a week or so when my wheels come, it will see some more abuse
EDIT: Be sure to use red locite on the PP bolts, and TQ them properly.. I Can say from experience its bad when they start backing off.
AWD: Jeff
Transmission & Drivetrain
Jun 2, 2010 08:04 AM
hayabusa160
Jun 18, 2008 01:28 PM
boostedsc61
Aug 24, 2006 12:43 PM
Just Checking In
Mar 27, 2003 09:41 PM
SoloSol
Mar 4, 2003 11:41 AM
