Sealing up oil pan gasket
I didn't want to spend the 20 bucks on hondabond. Do any of you use any type of sealant along with the oil pan gasket? Wondering if i should just put the pan on with the gasket or put the black rtv sealant with it. Thanks
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: Sealing up oil pan gasket (93c1sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93c1sol »</TD></TR><TR><TD CLASS="quote">I didn't want to spend the 20 bucks on hondabond. Do any of you use any type of sealant along with the oil pan gasket? Wondering if i should just put the pan on with the gasket or put the black rtv sealant with it. Thanks</TD></TR></TABLE>
Dude I live in St. Paul and I have some Hondabond in my trunk you can use. You don't want oil leaks on your turbo setup, I finally don't have any thanks to it.
Hmm.....$20 or all of your oil leaking out and toasting a bearing? Anyone who tries to charge $20 for Hondabond should be kicked in the nuts anyways.
$20?...was it coming in a gallon jug? A tube is around $6-$7 here. I would definately use Honda bond in the corners of the pan (and VC)
