clutch for boost
Old Aug 24, 2006 | 09:29 AM
boostedsc61's Avatar
Default clutch for boost
i tried searching, i found some info, but not enough. right now, i'm running an ACT 6 puck with a HD pressure plate and stock flywheel. im planning on making around 350whp & maybe 230 ft/lbs of tq. i'm also on a budget as most of us are. will the HD pressure plate hold up fine or would i need the xtreme? are there any other affordable clutches out there that can hold that power? has anyone had any boosted experiences with the TCS clutches from ekay jay? tia
Old Aug 24, 2006 | 11:34 AM
Mugencrxsir1's Avatar
Default Re: clutch for boost (boostedsc61)
Your HD pressure plate will most likely not hold long, I would definately upgrade the pressure plate to the xtreme. The xtreme pressure plate is good for 319ft/tq, and perfect for your application(since you already that the ACT...)
Old Aug 24, 2006 | 12:35 PM
EK k kay's Avatar
Default Re: clutch for boost (Mugencrxsir1)
I'd go with the XT pressure plate. I use that pp with the ACT hybrid street disc and it feels awesome. It's rated up to 270wtq.
Old Aug 24, 2006 | 12:43 PM
nickromeo's Avatar
Default Re: clutch for boost (EK k kay)
my suggestion to you is along with the upgaraded pressure plate to save ur pennies and grab a streetlite flywheel at the same time. that way u dont have to resurface ur stock one.
BoOsTiN Dc2
Apr 2, 2006 02:29 PM
91integraLSVTEC
May 25, 2005 11:49 AM
Just Checking In
Mar 27, 2003 09:41 PM
