retune when changing manifold?
Old Mar 28, 2005 | 06:05 PM
kell211's Avatar
Default retune when changing manifold?
going from a crappy manifold (ssac, obx, etc.) to a full race or neukin manifold, but leaving everything else the same (i already have a 3in. downpipe), is there any reason to retune the car? i live a couple of hours from a dyno, and was thinking of upgrading my manifold and was curious if the power increase would be significant enough to need to make another trip.
Old Mar 28, 2005 | 06:15 PM
nsxmatt's Avatar
With the Neukin upgrade on my car my powerband changed, turbo spooled faster, and made more power up top. I would retune to be safe or at the very least re-dyno the car with a wideband and make sure it is alright.
Old Mar 28, 2005 | 06:41 PM
kell211's Avatar
Default Re: (nsxmatt)
probably worth it. i see your from ky, where'd u go to dyno?
Evanmb44's Avatar
Default Re: (kell211)
yes it is definately worth getting it retuned. i would highly recommend it.
Old Mar 28, 2005 | 06:48 PM
PrecisionH23a's Avatar
Default Re: retune when changing manifold? (kell211)
Whenever you change anything that will affect air flow, it is necessary to have your maps retuned.
Old Mar 28, 2005 | 07:06 PM
kell211's Avatar
Default Re: retune when changing manifold? (PrecisionH23a)
i appreciate the replies, thanks.
Old Mar 29, 2005 | 12:54 PM
oxSLEEPERxo's Avatar
yep need to retune
Old Mar 30, 2005 | 01:16 AM
BoOsTiN Dc2's Avatar
Default Re: retune when changing manifold? (oxSLEEPERxo)
What if you change tranny or flywheel and clutch? If you change either one of those to a different one would you need a retune or no?
Old Mar 30, 2005 | 04:33 AM
USDM 4G VTEC's Avatar
Default Re: retune when changing manifold? (tRaCeBuStAbUsTeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR &raquo;</TD></TR><TR><TD CLASS="quote">What if you change tranny or flywheel and clutch? If you change either one of those to a different one would you need a retune or no?</TD></TR></TABLE>
no
like it has already been said
anything that affects air flow, needs retuned
Balachel
Dec 9, 2012 10:50 AM
8YourV8
Dec 11, 2010 09:29 AM
turbotime
Aug 20, 2006 10:25 AM
IGotVTECyo
Oct 18, 2005 09:28 AM
TitanMotorsports.com
Jul 7, 2004 02:30 PM
