retarding the timing
Old Aug 23, 2005 | 12:28 PM
rice a roni's Avatar
Default retarding the timing
ok, so when the distributor is sitting closer to the front bumper that is the timing being advanced right?and when its pushed back then its being retarded?? or did i get it backwards? and how would you know that you retarded it how many whatever degrees?? im so confused can someone help me out?
Old Aug 23, 2005 | 01:19 PM
CivicMike's Avatar
Default Re: retarding the timing (snow white)
dist twisted towards bumper is retarded.....dist twisted towards firewall is advanced....
you need an "Advance Timing Light" (got mine from Sears) to see how much timing your running exactly. Otherwise you use just your basic timing light and you can set your timing by reading the marks on the crank (only set stock timing +-2 degrees).
Old Aug 25, 2005 | 07:17 AM
Default Re: retarding the timing (CivicMike)
really? mine is really retarded then, my distributor is pulled more then half the way towards the bumper..not sure, i'll check though. so what is stock timing? 0 degrees?
sikek1
Apr 28, 2008 05:49 AM
HTn00b
Mar 10, 2007 10:17 AM
miksew
Jun 7, 2006 08:03 AM
johnbrooke86
Aug 23, 2004 04:49 PM
Tx92AccordExD
Jul 22, 2002 11:13 PM
