Resistor box wiring....
Old Apr 23, 2003 | 12:14 PM
  #26
jabroni95gsr's Avatar
Default Re: Resistor box wiring.... (Speedworks801)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedworks801 &raquo;</TD></TR><TR><TD CLASS="quote">Two words for you multimer. </TD></TR></TABLE>
True, but a regular one won't work..the signal will be too low and the needle will barely move, if at all! You need a digital multimeter....which is around $40
Old Apr 23, 2003 | 02:40 PM
  #27
omahaturbocivic's Avatar
Default Re: Resistor box wiring.... (jabroni95gsr)
I used a 10 dollar meter analog meter, you are just looking for continuity. Set it to the ohm meter unplug each injector clip and stick the probe in one of the clips. Then go through the connector in the above picture and probe each pin, when the meter bangs all the way to the right you got the wire that goes to the clip the probe is in. Cut and or mark that wire and move on to the next clip.
Old Apr 27, 2003 | 11:51 AM
  #28
acman1's Avatar
Default Re: Resistor box wiring.... (omahaturbocivic)
kinda stealing the thread...im not the best at wiring stuff. i have the resistor box w/ 5 wires coming out of it. couldnt i just cut the power wire coming from each injector pretty close to the end of the clip to make sure i was getting the right wire, and wire each wire on the injector side to each of the 4 red wires and just connect all 4 of teh wires coming from teh ecu side to eachother then to the 1 last wire on the resistor box? is that right?
Old Feb 10, 2004 | 07:24 PM
  #29
FlatTire's Avatar
Default Re: Resistor box wiring.... (acman1)
Sorry, but this is gonna be a little off topic, but is it possible to use RX-7 injectors, that are side not top positioned in a 94 civ ex? They are saturated and 440cc, Thanks for the help
Old Apr 12, 2005 | 12:18 PM
  #30
TURBO DC2's Avatar
Default Re: Resistor box wiring.... (GOLDBERG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">this is how you guys did it right?
[Modified by GOLDBERG, 9:35 AM 3/14/2003]</TD></TR></TABLE>
greatest evaR
Old Apr 12, 2005 | 08:21 PM
  #31
T4eg's Avatar
Default Re: Resistor box wiring.... (slammed_gsr)
I was going to use the hondata pic. But i decided to check and mine were different pin locations. So i would check it just to be safe.
Chris
Old Apr 14, 2005 | 03:18 AM
  #32
T-RO's Avatar
remember, you dont have to cut your OEM wires...:
https://honda-tech.com/zerothread?id=736737
Old Apr 14, 2005 | 03:35 AM
  #33
19sec beast's Avatar
Also, if anyone has a resistor box for sale... PM me!
Old Apr 14, 2005 | 07:24 AM
  #34
ITR981002's Avatar
Default Re: Resistor box wiring.... (BlueHatch00)
I work in the telecom industry, we use wire tracers or "Toners" everyday. They work awesome for tracing wires through a wire harness. I think Electricians use something similar when tracing lines through their installs. I believe you can find similar tracers for sale at any hardware store where they sell all the electrical supplies.
Old Mar 15, 2007 | 04:53 PM
  #35
nicko360's Avatar
* B A N N E D *
Default Re: Resistor box wiring.... (Infinity_Racer)
hmmmmm.....
i just did mine and I only cut the 4 wires on the left half????
did I do it wrong????
someone please let me know
Old Dec 5, 2009 | 10:54 PM
  #36
coombs's Avatar
here is a drawing
Old Dec 5, 2009 | 11:08 PM
  #37
coombs's Avatar
T9U4ReBgO
Dec 4, 2007 12:11 PM
Dunc
Oct 2, 2005 02:12 PM
shivern
Nov 28, 2004 08:51 PM
fast[R]
Jun 11, 2004 03:19 PM
boostin b16
Mar 2, 2003 03:03 PM
