Replaced head gasket, now more problems
Old Jan 12, 2009 | 09:25 PM
boostedjdmdc2's Avatar
Default Replaced head gasket, now more problems
Recently replaced head gasket, funny thing was that only the valve cover was milky as **** but the oil that i drained out wasnt really. Everything went well but now i have a lot of white smoke only coming from the oil cap when i take it off when the car is running. car isnt over heating and gonna do a compression test tomorrow. ive heard piston rings could maybe be going out? car hasnt been tuned, its on a base but its only been driven once since replacing the head gasket just to check.
Old Jan 12, 2009 | 11:04 PM
Default Re: Replaced head gasket, now more problems
maybe clogged pcv valve? also replaced intake manifold gasket with the head gasket. the engine didnt do this before the headgasket and IM gasket were replaced
Old Jan 13, 2009 | 06:35 AM
dpetro1's Avatar
dude, no need to start a new thread, you should have just updated us on your old thread.
anyways, it sounds like you may have hurt the motor, boosting on it untuned could have hurt the rings like you mentioned. let us now the results of the compression and leakdown tests
Old Jan 13, 2009 | 10:23 AM
doing the compression test when i get off work, will post up the results. my bad for starting new thread
Old Jan 13, 2009 | 10:49 AM
Wopsicle69's Avatar
did u resurface the head? did u inspect the sleeves for cracks?
shm91
Sep 1, 2013 03:56 AM
thatdannyboy
May 6, 2008 10:09 PM
fluk3d
Jun 14, 2007 11:46 AM
allmotorsi04
Apr 3, 2006 07:36 PM
spidermancivic
Mar 5, 2006 11:12 AM
