Boosted mini me ??????????????
Old Jan 12, 2009 | 09:19 PM
FERIO916's Avatar
Default Boosted mini me ??????????????
Im running a y7/y8 mini me on 10 lbs of boost after a hard pull my cars idle will get stuck at 2000rpm im wondering why this is ??? It stays this way untill i stop for min then is fine again is this bad how do i fix it ???? Any help will be apreciated thank you ............
Old Jan 12, 2009 | 09:42 PM
boostnbee's Avatar
Default Re: Boosted mini me ??????????????
im willing to bet your car isnt tuned. if this is the case then tune it, no more pulls till you do, you will just regret it later on.
Old Jan 13, 2009 | 11:03 AM
FERIO916's Avatar
my car is tuned on chrome pro ?????????????
Old Jan 13, 2009 | 11:25 AM
6000pounds's Avatar
sometimes my AEM fuel pressure regulator vaccuum hose pops off and my idly jumps up to 2k. but you said yours goes back down...
Old Jan 13, 2009 | 12:18 PM
HiProfile's Avatar
The two easy things to test for: vacuum leaks and tight throttle cable. A slight leak after the TB will make it hard for the IACV to hold idle well, and a tight cable will hold the TB open just enough to simulate that.
Otherwise it could be something to do with coolant temps, or your IAT compensation. The coolant or IAT sensor gets a little too hot, causing the issue in some weird way. FYI the stock coolant gauge will not move between 175F to 210F; above 200F is getting to be too hot.
ONECLEAN91
Mar 16, 2011 04:58 AM
Hill4589
12
Feb 10, 2010 03:49 PM
boomersz
22
Mar 11, 2007 07:58 AM
boomersz
Mar 9, 2007 10:12 AM
mattie_96
Dec 27, 2005 09:38 AM
