Reducing underhood temp.
Old 02-28-2005, 07:23 AM
Hyaboosta's Avatar
Default Reducing underhood temp.
I have my turbo in and tuned but now I am looking for ways to keep my reliablity. My first step is reducing the underhood temp. Other then a heatsheild on the manifold, what are some ways that you guys have lowered your temps? thanks
Old 02-28-2005, 07:30 AM
SiRLudeVtec's Avatar
Default Re: Reducing underhood temp. (Hyaboosta)
Well, i'm on expert on this subject but some guys wrap their turbo piping with some sort of material hopefully someone can elaborate on this for me. But a good way is to get a vented hood that actually works. No cheap immitation hoods. Also, get a largre intercooler. You can get an oil cooler, new radiator/fans. There are many ways....just be creative. Thats my moto.
Old 02-28-2005, 07:40 AM
Dangger's Avatar
You can wrap your manifold in heat sheilding wrap, if the manifold is tubular... it'll be difficult if it's cast molded.... wrapping your downpipe in this wrapping would also be a good idea. ... they also have ceramic heat sheilding paint you can have sprayed on or powder coated on... you can do this to your manifold, exhaust side of turbo, and downpipe/dumptube. i'm not sure if this is DIY or you may have to send it out... it's not that expensive.
jerry rigg some kind of clever heat sheild...
perhaps you can incorporate all of these methods for best results.
Old 02-28-2005, 07:50 AM
Hyaboosta's Avatar
Default Re: Reducing underhood temp. (Dangger)
Im not big on wrapping anything with thermal wrap seeing as how it destroys manifolds. I'll def. he looking into a koyo radiator and slimline fans.
Old 02-28-2005, 08:24 AM
Cray91's Avatar
The new rad wouldn't help the underhood temps.
I would suggest using heat sheilding tape on things that you are worried about melting. I would also look into moving your intake filter as close to outside air as possible.
The biggest thing would be a hole in your hood. I have seen a few "evo" hoods on civics, they seem to help. But that is a little sxtreme.
Old 02-28-2005, 08:50 AM
PM-Performance's Avatar
Default Re: Reducing underhood temp. (Cray91)
a rad and slimline fans wont do **** to help keep the underhood temps cool
Will just help water temps.
Hood scoop or spacers ont he back of the hood will help alot. My underhood temps were sickening. They got better with 1/2 inch spacers
Old 02-28-2005, 08:53 AM
beepy's Avatar
Default Re: Reducing underhood temp. (itr206)
My underhood temps sucked. So I hacked a hole in the hood.
Old 02-28-2005, 09:45 AM
Hyaboosta's Avatar
Default Re: Reducing underhood temp. (slow poke)
so spraying rustolium on the dumptube and dp save it from humidity and moisture?
Old 02-28-2005, 02:21 PM
oxSLEEPERxo's Avatar
do the hood trick with some washers, then air can escape easily at the top
Old 02-28-2005, 05:53 PM
Hyaboosta's Avatar
Default Re: Reducing underhood temp. (oxSLEEPERxo)
how much of a raise would be good enough?
and has anyone else done the rustolium trick?
Old 02-28-2005, 06:08 PM
dragstarr1411's Avatar
thermal coatings on the turbo housing manifold and down pipe can keep it alot cooler ive done so on my car and a few others and underhood temps are alot cooler it might be somthing to look into
Old 02-28-2005, 06:25 PM
DaX
DaX's Avatar
I need to do something...my hood is developing a brown spot...LoL. Good thing I don't have a sweet paintjob.
vangc6780
01-11-2005 11:41 AM
Corinthians
09-19-2004 08:34 PM
psycho_civic
01-16-2004 02:12 PM
Midwestrider
02-05-2003 03:40 PM
01ITR#700
01-11-2003 04:38 AM
Quick Reply: Reducing underhood temp.
