reducing boost
i have a 14b turbo and wondering how to reduce boost. i think stock wastegate is around 8psi, but would like to run ~5 for now. i was reading you can extend the arm on the actuator, but i can't find that post anymore. Anyone?
yeah...basically. make our own.. http://www.c-speedracing.com
theres also a few posts here about them right now on the 1st page./..
boost controllers can not be turned down...only up...sounds like you have an internal wastegate i think you spun it towards you too turn down boost (which ever way closes it more) good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kturboex »</TD></TR><TR><TD CLASS="quote">FYI a boost controller will not go below set wastegate pressure</TD></TR></TABLE>
Guess my 14.5psi spring is out of the question.
ok,, so all i have to do is spin the acuator --> wastegate connector to turn down boost? as easy as that? off a dsm 1g 14b turbo
yah 14.5 spring is about 10 psi too high for me
b20vtech
Jan 24, 2008 05:55 PM
avsrule414
Dec 10, 2005 09:07 AM
